Help needed - Viper 5904v
Old Feb 6, 2014 | 03:37 AM
DCRB's Avatar
Default Help needed - Viper 5904v
Specifically I need help with the remote start wiring. Basically I'm confused to where a few wires go, and if (other than the starter wire) any of the wires need to be installed in between the ignition switch and the body harness, or if they just tap into the harness and send voltage out when the key is off?
here's the diagram, which has very little explination:
The vehicle that it's being installed in is an mk4 Toyota supra... I know not a honda but you guys are REALLY helpful.
I've been using this link for the other wires i have to hook up
http://www.the12volt.com/installbay/...tail/2130.html
Basically how i'm reading it is:
H3/1 - simply tap into the existing wiring
H3/2 - install on the ignition switch end of the harness??
H3/3 - not needed for what we're doing, only need the remote start for the turbo timer and engine warm up feature
h3/4 and h3/5 are self explanitory
H3/6 - does this go in between the ignition switch and body harness? if so, does H3/1 go on the body harness end and this one go on the ignition switch end?
H3/7 - would go on the car side of the harness??
H3/8 - I don't think we need this? not sure what a flex relay is or would be used for?
H3/9 - No idea where this would wire up to, unless it hooks parallel to the body end of the starter wire?
I REALLLLLLLLY appreciate any help with this.
Old Feb 6, 2014 | 09:13 AM
k_than's Avatar
Default Re: Help needed - Viper 5904v
-tap into black/yellow at ignition switch harness
- tap to white/red at ignition switch harness
-tap to pink/blue at ignition switch harness
-correct cut black/white at ignition harness, h/4 starter side, h/5 key side
-tap to white/red at ignition harness
-tap to black/orange at ignition harness
-NOT USED
note-all red wires with inline fuse need to see constant 12v, i also reccomend to solder all connections
Old Feb 6, 2014 | 09:15 AM
k_than's Avatar
also you would want all neccassary remote start harness connected due to the fact that each wire power on a certain component on the car
accessory would power on accessory components like car stereo, igntion 2 will probably allow for climate control to work all these need to be hooked up in order for remote start to work properly
Old Feb 6, 2014 | 10:10 AM
DCRB's Avatar
thank you SO MUCH!! so i should hook the orange wire up to the pink/blue accessories wire?
Old Feb 6, 2014 | 10:34 AM
k_than's Avatar
correct, during remote start the accessory components in the car will be working as normal.
pink/white h3/7 should also be hooked to blck/orange and programmed as ignition2 per your vehicles diagram, by default on the alarm pink/wht is already programmed to igntion2 so just hook it up no programming needed .
F22B Accord
Apr 21, 2014 03:00 AM
ASR_RAMBO
Sep 4, 2009 07:41 PM
lorenzookc
11
Aug 2, 2009 08:02 PM
Scrim12
Dec 30, 2007 03:05 PM
XSIintegra
Sep 5, 2004 10:40 AM
