skunk 3 cams
You guys think these cams are to big for this setup?
Je 85mm 12.5:1 comp
full port job on gsr head
oversized valves.5
ported skunk manifold
bbk 70mm
rc 310cc
smsp 2.0l header
I was thinking of down grading to skunk stage 2 because of the problems i've had with the motor.Also is 4 degrees advance on the exhaust cam too much too run with these pistons I noticed the valve reliefs on the exaust side isn't as much as the intake side.When I pulled my head I noticed marks on the pistons on the exaust reliefs could this be from the 4 degrees adv on the cam also i'am using 30' cometic gasket.
Thanks guys
Je 85mm 12.5:1 comp
oversized valves.5
bbk 70mm
rc 310cc
smsp 2.0l header
Thanks guys
Advancing the exhaust cam increases piston to valve clearance-the exhaust valves close sooner in relation to the piston's upward motion during the exhaust stroke.
And you need bigger injectors for that setup-hope you have some form of programmable engine management.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">always follow manufacturers warnings. </TD></TR></TABLE>
yup..its there for a reason
JerseySiPOS
Jul 20, 2005 10:21 AM
blowme
May 3, 2005 03:10 PM
