how to read Autometer A/F gauge
i dont wanna hear no bullshit.. alli wanna know is What the gauge shuld read, when im full throttle?
i have a vafc 2, so any MINOR changes would be helpful...
also, inorder to change my VTEC crossover point i have to compensate for air/fuel....... WHat should the gauge read when i change my vtec point???
tahnks thats waht i wanetd...
anyways, im hittin up the dyno in the spring jw. do i have to get a wideband o2 sensor for them to tune it with? or they supply one usually?
thanks guys
thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkspeedVtec95 »</TD></TR><TR><TD CLASS="quote">tahnks thats waht i wanetd...
thanks guys</TD></TR></TABLE>
they supply, but for now id aim for just into rich...its too inaccurate, and the difference between slightly rich and stoich is prob. like 2 hp, while the difference between stoich and lean is about $2500 in a new engine.
also i know all engines are different but id shoot for around 4700-4800 vtec crossover and richen up there because it will still be on the low cam maps.
well when i go into vtec it just rises to RICH and bounces around the rich area....
i knwo its not to accurate but it was 30 bones, and some cool little light shows
call me aricer
call me aricer
I thought that after 80% throttle your ecu used the current map configurations and because of that you would read rich no matter how much you played with it????
Mostly because the use the o2 sensor after the 80% so the signal just goes rich???
Am I wrong? But having said that if I am right you would be tuning it for nothing because you dont even know what you are doing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude »</TD></TR><TR><TD CLASS="quote">I thought that after 80% throttle your ecu used the current map configurations and because of that you would read rich no matter how much you played with it????
Am I wrong? But having said that if I am right you would be tuning it for nothing because you dont even know what you are doing.</TD></TR></TABLE>
after 80 % it goes into open loop i think, which means no matter what your o2 says, it goes by the ecu maps, or in this case v-afc altered ones
Modified by fastludeh22 at 1:17 PM 9/5/2004
hondaguyexsi
Oct 8, 2005 06:58 PM
KStuned
Oct 6, 2004 11:39 AM
af, air, autometer, dyno, fuel, ga, gauge, gauges, howtoreadaafgauge, inaccurate, meter, read, reads, rich, stoichauto
