Need some help with cel #29
Old Sep 4, 2004 | 05:27 PM
dirtyfingers's Avatar
Default Need some help with cel #29
ok, i ran the cel code and i got cel 29 but when i refer to my book for the code it doesn't list a 29. the only ones i see is cel #229 throttle/pedal position sensor/switch "c" circuit intermittent, cel #329 knock sensor no. 1 - circuit input intermittent (bank no. 1 or single sensor), or cel #129 manifold absolute pressure higher than expected. when i did the cel test it blinked 2 long then 9 fast. am i not doing this correctly or are my cel codes wrong?
Old Sep 4, 2004 | 05:35 PM
chad's Avatar
Moderator
Default Re: Need some help with cel #29 (dirtyfingers)
you counted wrong!!!
Old Sep 4, 2004 | 05:40 PM
Default Re: Need some help with cel #29 (chad)
i don't think i counted wrong. it blinked long, long, 9 fast flashes so that would be 29 right? or would that be 119? but if it was 119 would it be like a fast, long, then 9 fast?
Old Sep 4, 2004 | 05:41 PM
chad's Avatar
Moderator
could be 20 and 9....
Malakai
10
Jul 28, 2008 02:49 PM
18gsir
Oct 7, 2007 05:55 PM
Draggin99Si
Aug 18, 2003 08:36 AM
