what wiring harness for b16
im swapping inthe b16a2 sir complete changeover from hmotorsonline.com besides mounts, what wiring harness will be needed for my 95 cx for it to be able to plug up to the b16 ecu/wiring harness?
you need an INTEGRA gsr 93 up.....or and ITR wire harness....
you will need to add vtec wires to the shock tower....
you could use an LS 93 wire harness and add vtec all the way....
search this has been covered way too many times!!
what is wrong with your stock harness? i did the same swap, just use stock harness and splice in wires for knock sensor, vtec and you will have to repin for the o2 sensor. not as hard as it sounds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6LazyPt »</TD></TR><TR><TD CLASS="quote">what is wrong with your stock harness? i did the same swap, just use stock harness and splice in wires for knock sensor, vtec and you will have to repin for the o2 sensor. not as hard as it sounds.</TD></TR></TABLE>
yeah but it looks like *** when you do it like that!! cut and splice sucks butt
Use Your CX harness. You will have to extend the backup light switch, rewire the o2 sensor for a 4 wire, and maybe extend another wire or so & run vtec wires.
Pinouts for the o2 at the ECU.
GRN/WHT - D22
WHT - D14
ORN/BLK - A6
YEL/BLK - Any yel/blk wire in the harness with power.
GRN/WHT - D22
WHT - D14
ORN/BLK - A6
msinsky14
Mar 27, 2006 05:53 PM
Charlie Moua
11
Apr 18, 2002 05:00 PM
