Crank Pulley Bolt What Size socket?
Old Sep 4, 2004 | 03:27 PM
Mark Finley's Avatar
Default Crank Pulley Bolt What Size socket?
I'm getting tools together for a Timing belt change for my 1.5 engine. THe crank bolt looks bigger than any size socket I have, so I;d like to know exactly what to buy. If anybody can remember exactly what socket size it takes, I'd really appreciate you passing that along.
Mark
Old Sep 4, 2004 | 06:00 PM
daubleaaron's Avatar
Default Re: Crank Pulley Bolt What Size socket? (Mark Finley)
its a 17mm on my 91 crx si
Old Sep 4, 2004 | 07:44 PM
Default Re: Crank Pulley Bolt What Size socket? (daubleaaron)
Wow, I had no idea it was that small. Thanks for the info.
Old Sep 4, 2004 | 08:54 PM
4drEF's Avatar
Keyboard Humorist
yup - 17mm
The axle nuts are the "big" ones.
Old Sep 5, 2004 | 07:01 PM
zCivic's Avatar
Default Re: Crank Pulley Bolt What Size socket? (4drEF)
SOHC crank bolt is 17mm
axle nuts- 32mm
most bolts for the engine are 10-12-14-17....well most of the entire car is made up of these sizes
Old Sep 5, 2004 | 07:03 PM
crxgator's Avatar
what you should do is bring it to a shop, have them zip off the bolt and then put it back on, its a bitch to take off for the first time...
Old Sep 6, 2004 | 06:41 AM
Default Re: Crank Pulley Bolt What Size socket? (crxgator)
I talked to a shop about doing that, and they suggested I put a breaker bar jammed up againt the frame and use the starter to break the bolt loose. Has anybody ever done that? I heard something about honda engines running backwards, and this trick wouldn't work on hondas.
Old Sep 6, 2004 | 09:14 AM
zCivic's Avatar
hehehe. I wouldn't suggest that. I've seen crank bolts siezed on so badly a 650 ft/lbs 1/2'' imact couldn't break them free. Hell my craftsman 1/2 breaker bar is twisted because of one. I know for a fact the starter will not break it free. My first swap the engine sat in the weather guessing for a long time, because the cylinders had rusted up. The starter wouldn't turn over at all. Had to use a breaker bar on the crank to free it up.
Old Sep 6, 2004 | 03:34 PM
vitrox's Avatar
19mm on b16.. 500ft lb impact for about 2 minutes broke it loose.
prodjay10
Jul 13, 2020 06:30 AM
B_Swapped93
Apr 9, 2013 08:21 PM
t0eKnEe
Feb 4, 2012 09:00 PM
theineffable
Honda Civic (2001 - 2005)
Jun 18, 2010 09:56 AM
accord91lx
Sep 16, 2003 08:40 PM
