d16z6 im
i have a 90 si with a d16y8 in it . i want to run the z6's IM. right now im running the a6's IM and it sucks. what do i need to change to run the z6's IM if i need to change anything at all. i plan on running the a6's injectors. so is there anything eles i need to know .
thanks
thanks
if you convert to obd1 you will have to use the z6 injectors with no resistor box. You will also need a p28 ecu for a manual civic, a conversion harness for the ecu(saves a lot of headache), and you will have to use an obd1 dizzy. I dont think I am forgetting anything am I?
ok so i need to use the sis injectors. with out a resistor box. so what i dont need done at all? the rest i know of, and what is a dizzy forgive me for asking?
if/when you convert to obd1, the si distributor (dizzy) will not work. I think you can use the obd-0 injectors without a resistor box and it should work, but I am not 100% on that one. They might work with it too...
ok so you are going to use the Z6's injectors, right? If so, then you do NOT need a resistor box. You just solder the power lines off the harness to the injector power lines. Thats it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumbtack »</TD></TR><TR><TD CLASS="quote">ok so you are going to use the Z6's injectors, right? If so, then you do NOT need a resistor box. You just solder the power lines off the harness to the injector power lines. Thats it.</TD></TR></TABLE>
why bother, just stick with the obd0 injectors and keep the resistor pack in there,. while using the obd1 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">
why bother, just stick with the obd0 injectors and keep the resistor pack in there,. while using the obd1 ecu</TD></TR></TABLE>
No matter ifyou are OBD-0 or OBD-1 the same rules apply.
Either you use the OBD-0 injectors iwth the resistor box
OR use the OBD-1 or OBD-2 injectors without the resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 »</TD></TR><TR><TD CLASS="quote">i believe the z6 and y8 are both about the same, and are both superior to the a6</TD></TR></TABLE>
Not even close in visual comparison.
The Y8 has a big football looking plenum on it.
The Z6 and A6 both have a smaller cylinder type plenum.
damn i forgot to ask this when this thread was alive. what is the code on the top of the d16z6 IM. the one i got from ebay says p32. but i thought the motor was a p28. im qeustioning if its the right manifold now. anyone now by chance?
thanks
thanks
