ABS REMOVE FOR TURBO SET UP?
Old Sep 4, 2004 | 01:38 PM
POWERINTEGRA's Avatar
Default ABS REMOVE FOR TURBO SET UP?
Hey guys what do you guys think about removing the abs system on a DA for fully built turbo set up. I was told the car won't stop on ABS is better to memove it and converted to none ABS is that right???
Old Sep 4, 2004 | 02:28 PM
Default Re: ABS REMOVE FOR TURBO SET UP? (POWERINTEGRA)
Anybody know about this????
Old Sep 4, 2004 | 03:36 PM
Fobtions's Avatar
dont mess with it. i know many 300+hp hondas with abs still intact. if aint broke dont fix it.
Old Sep 4, 2004 | 03:40 PM
Lord Helmet's Avatar
the only reason I can think of for removing the abs is to get some more room for the piping going to the throttle body. there's really no benefits for removing ABS unless the car is a full drag setup and need to remove the weight.
Old Sep 4, 2004 | 04:07 PM
Default Re: ABS REMOVE FOR TURBO SET UP? (sleeperciv)
Yeah the guy doing this did mention something about the pipes. Do you guys think he is maybe only looking for an easy way to put it together. I'm not feeling removing the ABS. He says is better because when I'm going fast and want to stop with the turbo it will be a little hard maybe it won't stop ummm
this is for a street car will do some drag but street minded built!!
Old Sep 4, 2004 | 04:27 PM
I still want to know what the problem will be with removing the ABS anybody????
Old Sep 4, 2004 | 05:21 PM
Fizzader's Avatar
There is no gain from removing your ABS!! I have upgraded my brakes to Brembo's and i still have the ABS and they are great espically they dont lock up under hard braking. You will not as much control under hardbraking from the stock brakes..
D-Rizzle3
Aug 18, 2008 02:27 PM
maxboost_50psi
Jun 17, 2006 06:13 AM
Sinner
Dec 23, 2005 12:54 PM
