Octane questions for a 90 Civic Si
From the 1990 Honda Civic Owners manual:
"Use gasoline from pumps labeled unleaded, with a pump octane number of 86 or higher. The pump octane number is an average of the Research (R) octane and Motore (M) octane numbers. Use of a lower octane gasoline can cause persistent, heavy "SPARK KNOCK" (a metalic rapping noise), which can lead to engine damage if severe."
Me, personally - Ever since I've had my 1990 STD hatchback, I've only ever used premium.
Well lets look at it this way:
Octane in a measure of how the fuel resists to burning or "pre-detonation". The lower octane you can use without detonation the better. Otherwise you may not be burning it throughly.
So the benefit on the stock motor with more octane would be the ability to run more timing. Get a timing gun and start by advancing your timing 2-4 degrees. You might get more but go up slowly.
To sum it up that is the reason boosted and high compression cars need more octane...because the motor is running hotter and may ignite the fuel too soon. Higher octane will not give you more power, it will allow you to run more boost, compression and or timing. That is where you will get your power.
HondaGuy02
May 6, 2004 11:37 AM
E-lude78
Feb 19, 2003 03:14 PM
1990, 2002, 86, 90, civic, compression, fuel, honda, numbers, octane, rating, recommendation, recommended, si, stock
