parts needed
im doing a GSR swap in my civic and I need a shift linkage and factory ecu harness becuase the harness that came with my jdm GSR is for a right side driver and its not hooking up the battery cable and everything is switched from my D16 i pulled out could anyone give me some advice
Sorry about the quility, we've got a shitty scanner. Try this link.
http://img.photobucket.com/alb...p.gif
If you can wait, I think I can modify a JDM GS-R engine harness so that you use it on a USDM motor. I just need to string it onto the motor sitting on the engine stand and then you can give it a try.
The starter harness is just a bit long, but otherwise fine to use.
My roommate also has an Integra shift linkage for sale.
halocore
Aug 5, 2008 01:18 PM
B19CivicHB
Nov 19, 2001 11:42 AM
