my Ep3 seats in my eg hatch !!!! I sit too talll
ok i got some mint ep3 front seats for my hatch. i bought them from this kid i know in my area with welded brackets to bolt right into eg/dc. The thing is that i like to sit low and these sit high. atleast too high for me.. I like how the sol seats fit in my car. I loved how i sat in them. I want to know if anyone knows how to make or anyone has done it to their seats. I would like to make them atleast 1-2" lower. any suggestions? thanks
b16a2, '00itr cams, euro type r tb 64mm, itr intake mani, jun lightened flywheel, jun cam gears, cai, skunk2(soon to be rsr) catback, greddy header and testpipe, apexi vafc, p28socketed kenji program, slammed 3-3.2" skunk2, 16" black 5zigen fnoc1 mint, kyb struts, mint del sol seats, momo wheel , jdm console, stripped rear int. strut bare all around, sparco 3pt harnss, autometer oil,volt,egt,5" tach w/shiftlight,a/f,oil press. , itr valve cover, m3 sideskirts,ww rear lip, cf front spoon lip, soon to be omnipower springs/retainers and jun2 or 3 cams. and maybe little bottle
Modified by klubhed1 at 11:43 AM 10/7/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">How are those seats on an EK? Would those EP3 seats fit in an EK without having to drill extra holes?</TD></TR></TABLE>ya i think they do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattjohnston »</TD></TR><TR><TD CLASS="quote">With those harnesses, your going to die.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klubhed1 »</TD></TR><TR><TD CLASS="quote">I would like to make them atleast 1-2" lower. any suggestions? </TD></TR></TABLE>
redo the brackets.
right after you shorten your signature.
redo the brackets.
The seats can only go so low, you just have to look at the rails and the small crossmembers that the stock seats bolt to. Even with the rails right up against the horizontal crossmembers, it looks like those seats will be pretty high.
You might have to do some cutting on the car if you really want to make them lower, but those seats seem a lot bigger, they're going to sit higher...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx »</TD></TR><TR><TD CLASS="quote">The seats can only go so low</TD></TR></TABLE>
as low as the floor plus an inch or two , flat floor mounting is the way I'd go.
i jus installed these the best way i knew how into a eg. it takes a long time and fabrication to do, but fits perfect and sits as low as the stock eg seats.
what you have to do is take your old eg seats and take off the foam and skin so its just the bare frame/skeleton. then do the same for the ep seats. then take the ep foam and skin and put it over the eg frame (you have to cut the welds on the eg headrest for these to fit) then bolt everything back up and youre good to go... take ur time on the ep seats so you dont rip the foam or suede and make sure u put everything back with all the springs to fit perfectly... ill have pics posted soon!
even if the seats had no brackets,you would still sit high cus the seats are just tall over all.i had a set in my integra and i hated hoe they fit.your head is almost on the roof
thats a negative, its because the rails and the frame on the stock ep seats are very thick/tall therefore they ride high. but this is like a eg seat with a ep skin. you sit much lower when swappin out the entire frame.
That’s the first thing I thought of when I saw those pictures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18OnTop »</TD></TR><TR><TD CLASS="quote">That’s the first thing I thought of when I saw those pictures.
</TD></TR></TABLE>Thats why i got rid of the seats, well that and they sat too tall. Now i got some mint *** del sol seats that sit a ton lower and look better imo. just more comfortable all around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LatinEM1 »</TD></TR><TR><TD CLASS="quote">how tall are you? im thinking of getting soem ep3 seats for mine...im only 5'6</TD></TR></TABLE> 6'1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlwhitecrx »</TD></TR><TR><TD CLASS="quote">
can you please take pics of the process and show us? does everything look stock? im still wondering if i should buy these seats or not.
