Do Ground wires work?
I was looking online just for misc things for my Accord and saw some ground wires. Do these actually do what they describe, and are they worth the money?? Im not looking for massive HP gains at all just wanna know if they work and if anyone has used them ??
http://cgi.ebay.com/ebaymotors...33692
hahaha
good find...I needed a laugh today.
I replaced by -BATT to chassis....block to chassis....and ALT to +BATT wires with 4AWG Stinger power wire and gold terminals but I did that only because I have about 4000 TRUE watts of power in the trunk powering two JL10W7s and a component set.
That will only give you more power if your OEM ground wires are in bad shape and not making a good ground....otherwise that is a gimmick
I don't know about gaining power from upgrading ground wires, but I know they will help you out if your stock ones are corroded or if you have a big pull from electical devices such as amplifiers.
A cheap alternative to buying a set of ground wires is to find some 4ga (Or Larger) welders cable, it works just as well and is REALLY cheap.
Some companies say you get a little power from this and I'm not going to start a dispute on that subject. But I will say you can do it yourself for much cheaper. Like stated above just buy some wire and cut to length.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22aAccord »</TD></TR><TR><TD CLASS="quote">they gain power by grounding them to different points. Import tuner did it one month </TD></TR></TABLE>
Not by grounding to different points but by strengthening the grounds. It helps the electrical system and in turn can give you better spark and a slight increase in power but nothing to write home to mom about.
IMO yes and no.
<u>Yes:</u>
Proven power gains
Better ground points/wire
Looks better
<u>No:</u>
Need dyno for which ground points are better
Costly kits (or diy
<u>Yes:</u>
Proven power gains
Looks better
<u>No:</u>
Costly kits (or diy
my h22 with and w/o grounding wires (my DIY special) has made a vast improvement in smoothness of the car...acceleration is a little smoother, but not necessarily faster...it's a good upgrade if you diy...
