Info on replacing Brake MC on an Accord.... (searched)
Old Sep 4, 2004 | 09:19 AM
Blaze45's Avatar
Brrraaaap!
Default Info on replacing Brake MC on an Accord.... (searched)
I searched around and was able to find alot of stuff on upgrading to a bigger one ect ect. I was just looking for the basic install and removal of one. All I have to do is remove the 2 nuts and the solid lines that go to it correctly right? Any other input would be great! tia
Blaze
Old Sep 4, 2004 | 10:33 AM
user 9782082308's Avatar
Default Re: Info on replacing Brake MC on an Accord.... (Blaze45)
You'll need to bench bleed the mc before you put it back in. Put fluid in the mc and put your fingers over the brake line holes. Pump the mc piston with your palm until all the air bubbles out of the reservoir. Hook your lines up loosly and bolt the mc to the booster. Then tighten the flair nuts. If done correctly you shouldn't have to bleed the system any more.
Old Sep 4, 2004 | 04:09 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Info on replacing Brake MC on an Accord.... (racerx)
Anything else that I need to know before I tackle it?
tia
Blaze
Pindanin
Jul 27, 2013 02:42 PM
boostedteg1203
Jan 21, 2010 05:58 AM
scotter031
Jan 30, 2008 06:48 PM
Flux
May 22, 2003 12:50 PM
Milano97
Jan 14, 2003 11:36 AM
