noise in b18b
Old Sep 4, 2004 | 07:04 AM
rizq777's Avatar
Default noise in b18b
just swapped in a b18b into my 95 hatch. i start it up and i here a clanking noise that sounds like it is coming from the block. when i drive you can here it clanging faster as i hit the gas. and when i am at idle you can hardly here it until i rev the motor up it makes the metal type noise at the drop of the rpms. one guy told me its the throw out bearing, what do you think.also the engine runs very strong.and the ide is fine. thanx
Old Sep 4, 2004 | 06:22 PM
Darkane's Avatar
Default Re: noise in b18b (rizq777)
It might be the throwout bearing... if it is it will only do it when the clutch is out. At idle try engaging the clutch and see if it goes away.
Old Sep 4, 2004 | 07:52 PM
ABK's Avatar
ABK
Default Re: noise in b18b (Darkane)
first of all if the car is making noise with a clutch engaged it won't be throw out bearing.
I fear the worst, crazzy piston slap (seen it happen, alot), or spun rod bearing (also common). Motor is junk, if you want rebuild it. Sorry.
Old Sep 4, 2004 | 07:59 PM
slambedcivic's Avatar
Default Re: noise in b18b (ABK)
sounds like a spun bearing. if you keep revving it up youll get a rod or part of one peaking through your block. you dont want that. drop the motor and do a build.
Old Sep 4, 2004 | 08:02 PM
ABK's Avatar
ABK
Default Re: noise in b18b (slambedcivic)
this is the reason why I won't buy a motor unless I straight up tell the guy if there is some big mechanical problem that I wasn't told about I'm going to drop the engine back where I found it and I want my money back.
Old Sep 4, 2004 | 09:32 PM
Phantastic's Avatar
it might be your clutch plate on backwards b/c my friend had the same problem with his h22 hatch and now it's running good after he switched it around
SPITVENOM67
Oct 12, 2012 09:33 AM
akacoke
Jun 27, 2011 10:48 AM
derblott
24
Mar 15, 2006 11:59 PM
sracing
Aug 27, 2003 09:50 AM
DeDonDeRosa
Nov 23, 2002 09:03 AM
