DA teg foglight trick? How do you do it?
Old Sep 3, 2004 | 11:04 PM
matman4444's Avatar
Default DA teg foglight trick? How do you do it?
I have a 92 integra and I have seen people who make it so you can have the fogs on without using the headlights, i know you have to rewire the button or something? If you know anythin about this please help me out or link me up to another thread that i missed w/ search
Old Sep 3, 2004 | 11:06 PM
91ls-v's Avatar
Default Re: DA teg foglight trick? How do you do it? (matman4444)
The cool thing about this method is that you'll wire the fog switch to another switch so that you won't have to turn any lights on and cause your interior light (radio, clock) to dim during the day. You'll be concerned only with the fogs switch and the rear defogger switch right next to it.
Disconnect the battery.
O.K., both switches will pop out towards you with a screw driver. The fog switch has five wires, the defogger has six.
First, find the red/yellow wire in the FOGS switch. Cut this wire about 2" away from the switch.
Now take the cut wire that's STILL attached to the switch and splice it into the black/yellow wire of the Defogger switch.
You're done. Now cover up everything with electrical tape including the other parts of the cut red/yellow wire of the fogs switch and see if everything works. The fogs should come on/off independently of the defogger switch which means you DON'T have to mess with the defogger switch ever. Just turn off/on the fogs button anytime and they WILL turn off automatically when the ignition is off.
Old Sep 3, 2004 | 11:07 PM
91ls-v's Avatar
Default Re: DA teg foglight trick? How do you do it? (91ls-v)
oh yeah 4got to tell you check out g2ic.com it's a good site
if you can't afford the jdm 1 piece headlights go to the junkyard and get the legend foglight covers...it looks exactly liek the jdm one piece when on
one more thing is do the 9007 bulb conversion it is more clear with that conversion
sorry for a long post
Old Sep 4, 2004 | 09:46 AM
matman4444's Avatar
yep i got the 1 piece already, im not sure what bulbs are in there but ill find out later cuz one of them is out, ill be doing the fog trick after i get back from the movies, thanks for the help
you have pics of yor teg?
http://www.geocities.com/hooli...s.htm
Old Sep 4, 2004 | 10:22 AM
91ls-v's Avatar
oh...you bought that prelude converted integra...with b20 vtec or b20 right??
since you have the jdm 1 piece you will not need the legend fog light covers..
it should already be yellow fogs
juss do the switch rewiring.
Old Sep 4, 2004 | 01:28 PM
matman4444's Avatar
yeah thats the car, it has the yellow fogs, im bout to try fixing it right now, ill get pics up if i finish it
Old Sep 5, 2004 | 11:44 AM
matman4444's Avatar
what do you need for the 9007 conversion? what are the benefits? i have 9003's and even though i put silverstars in they still dont seem very bright
Old Sep 5, 2004 | 12:06 PM
DTR_Projekt's Avatar
Will this trick work with a DC with JDM front? i wanna be able to run my fogs without my headlights on.
Old Sep 5, 2004 | 12:39 PM
91ls-v's Avatar
Default Re: DA teg foglight trick? How do you do it? (DTR_Projekt)
should be the same thing if your fogs are wired up to a switch...but the colors mayb not be the same so test out which one is the constant power for the defroster first.
Old Sep 5, 2004 | 12:40 PM
91ls-v's Avatar
the stock jdm 1 piece bulbs should be brighter then the 9007 i believe...not sure...
641iowaguy641
Jun 19, 2013 01:53 PM
Delano Devine
Honda Civic (2001 - 2005)
Mar 21, 2009 07:41 PM
93DA9
Lighting
Nov 24, 2008 09:47 PM
mugenDA9 lover
Sep 24, 2006 05:25 PM
Simple
13
Jan 10, 2004 07:57 AM
