Very Strange Brake Problem.....
Old Sep 3, 2004 | 08:16 PM
luder94-ChrisA's Avatar
Default Very Strange Brake Problem.....
This first started at an autocross two weeks ago....finished my run & pressed the brakes hard (they worked perfectly) as I went through the finish & shifted into neutral to check out my time....suddenly, with the brakes pressed, the idle jumped up to 2000 rpms & oscillated up & down for the next couple of seconds.....This happened after every run - the brakes work perfect but the idle jumps....
Now, if my prelude is just idling in my driveway & I pump the brakes, the idle jumps up to 1500 rpms & then to 2000 rpms before coming back down....I checked for leaks between the brake booster & the intake manifold & can't find any....Could this be a possible sign of brake booster/master cylinder failure or is there something I'm missing?
slammed92EG
Suspension & Brakes
Oct 17, 2009 09:53 PM
slim9300
Jul 14, 2004 10:14 AM
slim9300
May 10, 2004 07:04 PM
slim9300
May 10, 2004 07:03 PM
importimage
21
Apr 13, 2004 04:08 PM
