What do i need for a transmisson swap??
Old Sep 3, 2004 | 08:09 PM
civickid32's Avatar
Default What do i need for a transmisson swap??
what do i need for a transmission swap for a 95 civic from an automatic to a stick?
Old Sep 3, 2004 | 08:38 PM
chad's Avatar
Moderator
Default Re: What do i need for a transmisson swap?? (civickid32)
search function....
covered once a week for the last 3 years cause you all settle for an automatic when if you had the patience you'd find a 5 speed!!!
Old Sep 3, 2004 | 08:51 PM
Lord Helmet's Avatar
Default Re: What do i need for a transmisson swap?? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">search function....
covered once a week for the last 3 years cause you all settle for an automatic when if you had the patience you'd find a 5 speed!!!</TD></TR></TABLE>
it's right in the upper right corner
Old Sep 3, 2004 | 10:07 PM
MulletManRockStar's Avatar
shifter,linkage,pedals,hyrdraulic master cyclinder,lines and etc. cause i forgot
Old Sep 3, 2004 | 10:19 PM
redline201's Avatar
Default Re: What do i need for a transmisson swap?? (MulletManRockStar)
ecu also
Old Sep 3, 2004 | 10:35 PM
99blackcivicSi's Avatar
Default Re: What do i need for a transmisson swap?? (redline201)
don't forget to jump the park switch
and don't put the interlock box back in
AndrePerras
Mar 1, 2007 08:53 PM
ghostcivic2269
Jan 17, 2007 03:07 PM
quinnc
Oct 18, 2005 07:55 PM
97 honda
Jan 20, 2005 10:35 AM
dozerbro95
Oct 24, 2004 08:32 PM
