Blank/non drilled 3 bolt style flange for stock converter?
Old Sep 3, 2004 | 07:49 PM
Sprockets's Avatar
Default Blank/non drilled 3 bolt style flange for stock converter?
I finally got my 3" exhaust flanges, but they don't match up with the bolt pattern of my catalytic converter, and there would be leaks on the 3 sides. The final piece of my custom exhaust puzzle is a blank flange that's the same size as a 3" 3 bolt flange around the outside. I'm going to cut off the OEM converter flange, then have a new one welded in its place with the center cut out to the same diameter as the cat. This is so I can swap the converter in and out for inspection. Any ideas where I can find this?
spAdam
Welding / Fabrication
Jul 27, 2012 12:07 PM
Stillmatic22
Jun 20, 2005 12:24 PM
8krdline
Apr 12, 2005 01:31 PM
speedymon
Oct 17, 2003 02:04 AM
TurBoTeG
Jul 5, 2002 11:06 AM
