I need help from someone with a DPFI car (or knowledgeable)
Old Sep 3, 2004 | 04:15 PM
notfastenough's Avatar
Default I need help from someone with a DPFI car (or knowledgeable)
I'm having problems with my car and wanted to see if the source is within the throttle body/injector housing.
I took the cover off the top of the throttle body (black lid to the bowl on top) and opened the tb butterfly and the air meter type thing above it at the same time. When I looked down into the bore of the tb, I saw standing liquid at the bottom. I need to know if this is normal, or the source of my problems. Please help!!!!
Old Sep 3, 2004 | 04:18 PM
MENACE's Avatar
Default Re: I need help from someone with a DPFI car (notfastenough)
Ive seen them do that befor. Alittle Gas ( liquid) is Acceptable. If it a whole Lot it will flood the Motor and it might not start.
Old Sep 3, 2004 | 04:20 PM
The liquid fills up the entire bottom of the intake manifold (I assume) I can see no metal at the bottom of the hole.
Old Sep 3, 2004 | 04:23 PM
MENACE's Avatar
Default Re: (notfastenough)
So i Assume when you try to start the car. It wont start and smells like gas then huh.
If thats the case i bet one of you fuel injectors is stuck open.
Old Sep 3, 2004 | 04:30 PM
Default Re: (MENACE)
I'm sure there is a way to test the injector with a volt/ohm meter, but I don't know which plug is for the injectors. I don't have the helms manual for a dpfi car. Any help on that?
Old Sep 3, 2004 | 04:42 PM
MENACE's Avatar
Haha yeah i dont know how to test the Injectors on a DPFI car Ether. But i would figure they would be the same as testing any other Saturated Honda Injector. I see if i can find some infor on that.
But for the time being you can Just turn the Ignition on and see If its Squirting any fuel, When youre not giving it any gas. If you have a pool of gas that big it got to be quite a leak.
Old Sep 3, 2004 | 05:59 PM
Well, I figured out that the pool is has been caused by cranking it over that many times Soaked it up with a paper towel and got it to run for just a split second Now if I can just get it to idle...
Old Sep 3, 2004 | 11:41 PM
CRseXy's Avatar
yah its running to rich. Check all ur hoses. blah blah blah. check ur injectors. if you have to replace the injectors. Just Swap to MPFI
Old Sep 5, 2004 | 11:53 AM
Thanks for the help. Car is running like a champ now
Old Sep 5, 2004 | 12:30 PM
MENACE's Avatar
What did it end up being. Just flooded?
Old Sep 5, 2004 | 01:27 PM
Yea, it was flooded.
Because I did a dumb thing. Have you ever messed up the firing order?
Old Sep 5, 2004 | 01:33 PM
MENACE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">Yea, it was flooded.
Because I did a dumb thing. Have you ever messed up the firing order? </TD></TR></TABLE>
Happens to the best of us.
dmossdrum91
Sep 20, 2015 02:16 PM
xuecivic
Apr 2, 2010 12:02 PM
DC2SIR-G
Aug 7, 2006 07:02 PM
si 1
Dec 26, 2005 02:26 AM
Audio28
Dec 21, 2002 01:06 PM
