Are these the correct alignment specs for 2001 Type-R?
Old Dec 6, 2001 | 08:07 AM
onyx00's Avatar
Default Are these the correct alignment specs for 2001 Type-R?
Caster Angle: 1 degree 10' +/- 1 degree
Camber Angle:
Front: -0 degrees 30' +/- 1 degree
Rear: -0 degrees 45' + 0 degrees 45' or - 1 degree 15'
I am getting an alignment at a tire place who is mounting my new tires, and wanted to have them do the alignment, is this a good ideA?
I need answers ASAP, leaving soon!
Old Dec 6, 2001 | 08:14 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Are these the correct alignment specs for 2001 Type-R? (onyx00)
Everything is in the manual.
Old Dec 6, 2001 | 08:16 AM
onyx00's Avatar
Default Re: Are these the correct alignment specs for 2001 Type-R? (Rguy)
That's where i got these numbers, just checking.
Old Dec 6, 2001 | 08:18 AM
Rdriver's Avatar
I was told my car couldn't be alligned with out a camber correction kit. I have a 1/2 drop though.
yoshi234's Avatar
I shoot brides
looks about right.
my car used to follow the ruts in the road pretty bad until I had the alignment set to my liking: max toe out in front (w/in spec) and zero toe in rear. Dealer had no problem doing this for me...thanks Peyton Cramer Acura
yoshi
Old Dec 6, 2001 | 08:38 AM
Willard's Avatar
Default Re: Are these the correct alignment specs for 2001 Type-R? (yoshi234)
Sounds familiar..
Will
Old Dec 6, 2001 | 10:58 AM
KF_S2000's Avatar
Default Re: Are these the correct alignment specs for 2001 Type-R? (Rdriver)
Yeah, but with such a minor drop, your camber will probably be just a tad bit more negative, but definitely still within spec.
wreckedmyteg
Oct 5, 2005 07:50 PM
RallyRedGT-V6
May 19, 2004 04:00 AM
Kavehman
Nov 6, 2003 07:58 PM
paz92ls
Oct 17, 2003 05:18 PM
1.7na
Mar 20, 2003 03:22 PM
