So many parts forsale, unbelieveable!
Old Dec 6, 2001 | 07:49 AM
TurboT's Avatar
Default So many parts forsale, unbelieveable!
was turbo, decided to go all motor...
e-mail or IM me for prices through honda-tech, aol (chungt1),
or chungt1@aol.com
most items will be sold on best offer....
pick up is a plus!
Engine:
-98 GSR b18c1 block, Darton sleeved and cylinder walls pinned by BRE, knife-edged crankshaft and balanced to 10k rpms, freshly decked 0.010", 0.025" overbored, ARP head studs Crower rods, oil pressure switch sensor,oil baffle plate, oil pan, oil pick up, already tee'd for -4 AN turbo oil feed line, VIN JH4DC238XWS000346 -
ITR stock parts:
-98 ITR intake and exhaust cam with STR silver race cam gears -
-ITR flywheel used, 3k miles -
GSR stock parts:
-00 GSR head assembly, stock valves, stock valve springs, stock retainers -
-00 GSR b18c1 head bolts -
-00 GSR b18c1 stock cams with stock gears -
-00 GSR b18c1 driver side engine mount assembly -
-00 GSR b18c1 bare intake manifold -
-00 GSR b18c1 IAC valve -
-00 GSR b18c1 fuel injectors and fuel rail -
-00 GSR b18c1 valve cover -
-00 GSR b18c1 pistons and rods -
-94-00 Integra engine lower mount, part #50841-ST7-Z00 -
-98 GSR b18c1 vtec solenoid -
-00 GSR b18c1 purge valve solenoid -
-00 GSR b18c1 upper and lower power steering brackets -
-98 GSR b18c1 coolant pipe and thermostat housing with temperature switch -
-98 GSR b18c1 distributor assembly, complete -
-00 GSR A/C bracket assembly with mount -
-98 GSR b18c1 alternator bracket set -
-98 GSR b18c1 stock spark plug wire set -
-98 GSR upper timing belt inner and outter covers (cut for cam gears) -
-98 Acura Integra stock springs -
-94-00 Integra Evaporator assembly -
-94-00 Integra A/C compressor with clutch assembly -
-94-00 Integra condensor with mounting rail -
-94-00 Integra dryer with bracket and bolts -
-94-00 Integra A/C fan -
-98 GSR hydrolic clutch piston, hardline, and flex hose -
-98 Integra front end package, hood, bumper cover (grilled for intercooler), fenders, head lights, clear front lights, hold down bar, front support assembly, front core support, all painted yellow, WW front lip, and all hardware -
-98 Integra steering wheel, leather wrapped, airbag, with cruise control equipment (switch, harness, control module, control unit, cable, pedal hinge) -
-98 Integra front bumper amber turn lights -
Civic Si stock parts:
-00 si b16a2 head bolts -
-00 Si b16a2 stock cams with stock gears -
Turbo stuff:
-JE 9:1 compression pistons, 0.020” overbore, wristpin and locks, 6k miles-
-TurboXS High Performance Manual Boost Controller -
-Pro Drive billet oil pump gear, brand new -
-Miscilaneous silicon turbo hose coupling -
-T-bolt hose clamps -
-LS tranny final gear -
Electronics:
-DEI remote window roll up and roll down control system -
-Integra Type-R stock radio with security code (lights up amber) -
Others:
-Sparco footrest, for BMWs, anodized red, brand new -
-Greddy Power Extreme exhaust for 94+ GSR -
-Permacool oil cooler with -10AN welded fittings -
-Reinforced hood locking system -
-Burton 156cm Charger snowboard, 2000 model, used once -
[Modified by TurboT, 1:52 PM 12/17/2001]
Old Dec 6, 2001 | 10:37 AM
TurboT's Avatar
Default Re: So many parts forsale, unbelieveable! (TurboT)
ttt
Old Dec 6, 2001 | 11:22 AM
dot's Avatar
dot
New User
HOW MUCH FOR THE ITR INTAKE?????
Old Dec 6, 2001 | 11:31 AM
Rory Breaker's Avatar
Default Re: So many parts forsale, unbelieveable! (dot)
Good god thats a lot of stuff!!!!!!
3 boxes of plugs meaning 3 sets or 3 plugs?
And how much for the ITR fly?
Thanks.
Old Dec 6, 2001 | 01:21 PM
millertime's Avatar
New User
Default Re: So many parts forsale, unbelieveable! (newgsrdriver)
hey i as the one talking to you about the I.C but I guess you sold it to your friend, anyways, how much for this? and how much WHP will that turbo put out
Turbo/Manifold combo:
-Garrett Turbo T3/T4, 60-1 trim, stage 3 exhaust wheel, .63 A/R, freshly rebuilt, MaxRev stainless steel turbo manifold for b series engines, Tial 40mm wastegate, purple anodized, 0.8 bar spring, wastegate dump tube, wrapped with thermal tape, downpipe, 3" diameter, flexpiped and wrapped, non-a/c compatible, AN fittings, -4AN for feed, -10AN for drain, braided -10AN oil drain line with Earl's fittings, -10AN to 1/2" NPT adapter fitting included, all nuts, bolts, vacuum fittings for turbo and wastegate included, package price -
Old Dec 6, 2001 | 01:24 PM
millertime's Avatar
New User
also interested in greddy b.c, greddy TT and maybe missing link, also maybe we could work out some kind of trade with oil pans, if i buy your turbo stuff.
Old Dec 6, 2001 | 03:15 PM
TurboT's Avatar
Default Re: So many parts forsale, unbelieveable! (millertime)
dang, you must have some bad luck....
sold the turbo stuff...
profec b sold
tt sold
missing link pending sale
Old Dec 6, 2001 | 03:30 PM
Audipwr1's Avatar
&S ultra safeguard version 2, with dual monitor and all hardware -
-Autometer oil temperature gauge, 2 1/16", phantom series, with sensor and hardware-
-Autometer oil pressure gauge, 2 1/16", phantom series, with sensor and hardware -
-Autometer coolant temperature gauge, 2 1/16", phantom series, with sensor and hardware -
-94+ Integra driver side gray pillar with carbon fiber Autometer dual and single gauge pod
Denso 680cc peak/hold injectors, low impedance, 0 miles since RC engineering calibration --
prices on these please, email me at robinm2@rpi.edu
Old Dec 6, 2001 | 04:05 PM
millertime's Avatar
New User
Default Re: So many parts forsale, unbelieveable! (Audipwr1)
God ******* damn it!!!!!!
Old Dec 6, 2001 | 08:28 PM
owen_the_soyboy's Avatar
holy LOTS of stuff!!!!!!
good lord MAN!
Old Dec 7, 2001 | 03:21 AM
b18c1_powered_si's Avatar
Default Re: So many parts forsale, unbelieveable! (owen_the_soyboy)
anyone want to see my complete lists? hahhaha. not trying to compete it's all good man.
Old Dec 7, 2001 | 07:49 AM
TurboT's Avatar
Default Re: So many parts forsale, unbelieveable! (b18c1_powered_si)
e-mail me if interested
thanks
Old Dec 7, 2001 | 10:00 AM
TurboT's Avatar
KA POW!
Old Dec 7, 2001 | 01:07 PM
jdm_latino's Avatar
how much for the gsr head
please e-mail me.
Old Dec 7, 2001 | 02:45 PM
TurboT's Avatar
Default Re: So many parts forsale, unbelieveable! (silvercivicb)
e-mail me please...
Old Dec 8, 2001 | 02:53 PM
TurboT's Avatar
ttt
Old Dec 8, 2001 | 06:12 PM
CTR94Joes's Avatar
How much for tha ITR exhaust cam??
Old Dec 8, 2001 | 08:48 PM
Krow's Avatar
good lord MAN!
Old Dec 9, 2001 | 08:25 AM
TurboT's Avatar
Default Re: So many parts forsale, unbelieveable! (Krow)
e-mail me....
thanks
terry
Old Dec 9, 2001 | 02:53 PM
TurboT's Avatar
ttt
Old Dec 10, 2001 | 07:58 AM
TurboT's Avatar
Old Dec 10, 2001 | 02:45 PM
Mugenlude's Avatar
You have mail.
Old Dec 10, 2001 | 06:02 PM
iH8RICERZ's Avatar
how much for the itr cams and fly wheel?
Old Dec 10, 2001 | 07:53 PM
racerman33's Avatar
hey was wondering about how much u wanted for the vtec solenoid, tb, distrubitor,
let me know call me at (808-439-7050) or email me at (ken_and_melissa@hotmail.com) or aim me (racerman33) thanks
Old Dec 10, 2001 | 08:25 PM
Hapa DC5's Avatar
Default Re: So many parts forsale, unbelieveable! (racerman33)
check your mail turbot
