Camber kit for Recently lowered accord
Old Sep 3, 2004 | 01:31 PM
idragen's Avatar
Default Camber kit for Recently lowered accord
if my drop is 1.8 front, and 1.3 rear...do you guys suggest a camber kit...thanx
Old Sep 3, 2004 | 03:04 PM
dougieb3's Avatar
Default Re: Camber kit for Recently lowered accord (idragen)
Eibach is what I went with just talked to another hT Member and he is pricing one for his 98 accord. Call me and I can help you out. 4238429292 or emial me Noisepollution@soon.com. My Buisness is called Noisepollution and I am trying to get into mre performanc then car ausio so give me a call if you need anything. Doug
Old Sep 3, 2004 | 04:32 PM
H2290's Avatar
Default Re: Camber kit for Recently lowered accord (dougieb3)
This guy is killing me. It's his second advertisment in 4 posts I have looked at.
As for your question, 2" is the general rule of thumb. You should be fine.
Old Sep 3, 2004 | 05:31 PM
idragen's Avatar
Default Re: Camber kit for Recently lowered accord (H2290)
Lol yea i was reading his post, i was like okay it has nothing to do with my question ....anyways so anything lower than 2 needs a camber kit...hmm...even with my drop it seems like theres quite some negative camber in the rear...but since i ve seen some previous post saying the same thing " 2 inches as the rule of thumb"...i guess i dont need one then ...right?
Old Sep 3, 2004 | 10:08 PM
H2290's Avatar
You shouldn't need one but if you feel like your tires are wearing too quickly due to bad camber get one anyways. It can't hurt. Just try it and see, if it helps good, if it doesn't keep it in case you decide to go lower.
Old Sep 3, 2004 | 11:52 PM
idragen's Avatar
thanx for the info...didnt really want to spend more money, even more reason not to
Old Sep 4, 2004 | 12:58 AM
HAccord96's Avatar
What year is your Accord?
Old Sep 4, 2004 | 03:35 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idragen &raquo;</TD></TR><TR><TD CLASS="quote">if my drop is 1.8 front, and 1.3 rear...do you guys suggest a camber kit...thanx</TD></TR></TABLE>
The smart thing to do would be to have it put on an alignment rack and see how off your camber/caster/toe are. Whenever you change the geometry of the stock suspension, all three will change. They will all affect your tire wear. It takes as little as a month of driving to wear your tires unevenly. With that can come a rough ride and droaning. Nothing worse than a car that sounds like an airplane going 45 down the street cuz the tires are chopped up.
People that drive cars with their wheels looking like this / --- \ are idiots.
Do it right
Old Sep 4, 2004 | 10:58 AM
idragen's Avatar
Default Re: Camber kit for Recently lowered accord (Escobar)
my accord is a silver 2003 coupe.
Old Sep 4, 2004 | 11:00 AM
idragen's Avatar
oh yea, i probably will get an alignment done pretty soon..its been about 2 weeks after the drop...any suggestions on cheap places to get them at?....cheapest i have found was at sears auto center...60 bucks.
Old Sep 5, 2004 | 05:56 AM
rsidhu's Avatar
I have a 95 Accord LX and lowered my car with H&R Springs (1.25" drop). After about 6 months (around 3,000 miles) my front wheels were pretty worn on the inside and as I was new to this, didn't realize how much my camber was affected.
I would definitely get your alignment checked out as soon as possible because you don't want to have to buy a new set of tires in 6 months. (more expensive than a camber kit)
I bought an Eibach kit of eBay for around $100.
Old Sep 5, 2004 | 01:08 PM
H22SiRaccord's Avatar
anything really at of lower than 2in u will need a camber kit do to you will be going through tires like crazy. Anything really higher than 2ins you should be fine.
Old Sep 6, 2004 | 06:33 PM
m0t0rhead's Avatar
Default Re: (H22SiRaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22SiRaccord &raquo;</TD></TR><TR><TD CLASS="quote">anything really at of lower than 2in u will need a camber kit do to you will be going through tires like crazy. Anything really higher than 2ins you should be fine.</TD></TR></TABLE>
I wouldn't trust your 400$ tires on that assumption that "yours SHOULD be fine".
Even less than a 2" drop will affect all 3 of your alignment settings. I should know... I do alignments at my shop.
Also, most garages only set your toe and send you on your way. If you were smart, you would ask for your "before" and "after" printout which lets you know how far you were off on your caster/camber/toe and what they set it to.
Old Sep 6, 2004 | 07:54 PM
idragen's Avatar
Default Re: (Escobar)
thanx escobar...i will be going to the alignment shop soon...just wondering, how much does ur shop charge, i just want some idea... thanx..and does it take long?
Old Sep 7, 2004 | 04:14 AM
m0t0rhead's Avatar
Default Re: (idragen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idragen &raquo;</TD></TR><TR><TD CLASS="quote">thanx escobar...i will be going to the alignment shop soon...just wondering, how much does ur shop charge, i just want some idea... thanx..and does it take long?</TD></TR></TABLE>
It can be time consuming depending on how off your alignment is and if you want to correct everything. Sometimes you have to purchase parts like a cam bolt or shim, or even a camber kit. On average a takes a good tech a half hour to set your toe properly. Anything more and it depends on what parts you have to install to correct it.
We charge 39.95 for a front end alignment (toe set). If you camber is off, it's additional parts and labor.
Old Sep 7, 2004 | 04:58 AM
azian21485's Avatar
you can get 1 year worth of unlimited allignments at NTB for $80 or w years for $100...so if you ever decide to change your suspension setup just go back there to get it realigned for free..my suggestion
hamiltonj2w1
Jan 18, 2007 12:28 PM
jtran22
Suspension & Brakes
Apr 23, 2006 10:07 PM
StarRizer
May 15, 2005 01:16 AM
OdysseyHF
Nov 29, 2003 07:25 AM
