question about b16 tranny gears?
Old Sep 3, 2004 | 12:58 PM
oneslodx's Avatar
Default question about b16 tranny gears?
hey i have an LS cable tranny but im about to go to UTI and was wanting to put S1 gears and synchros in my tranny once i learn how to do so. i know they are all the same tranny case so i figured its possible, my question is where can u buy new gears and stuff? or can u even get them anymore? if anyone knows i greatly appreciate it
Old Sep 3, 2004 | 07:32 PM
oneslodx's Avatar
bump
Old Sep 3, 2004 | 08:24 PM
PyroProblem's Avatar
Default Re: (oneslodx)
It depends which gears you want to change out.I just put an LS 5th gear in my ITR tranny with the JDM final drive.
Supposedly some gears are not interchangeable because they wont fit on the counter or mainshafts. Basicly your counter and mainshafts dictate which gears you can swap in.Some gears may require you to change the shafts while others will slide right on.
All parts should be available at the local honda dealer however they are pretty expensive.My advice is to hook up with someone in parts and see if they can help you out.
If you want S1 (B16?)gears,I think your gonna have to replace pretty much everything inside your LS trans.(Y1?). You may want to consider just changing out your final drive gears.This will effectively do the same thing for less $. Or you could find a cable S1 and replace whatever you need.
Good luck at UTI. I attended the one in Houston and then when to the Porsche PTAP program. I just recently started working at a Porsche dealer and finally making some decent money.
A little advice...Study and do your best and get into a manufacturer program.I know guys that graduated from manufacturer programs and are STARTING OUT AT $19 AN HOUR.
Good luck with the trans. and UTI
Old Sep 4, 2004 | 06:02 AM
oneslodx's Avatar
Default Re: (PyroProblem)
hey man thanx a lot for the info, yea im currently stuck between doing the industrial diesel or just doin bmw step, im leaning towards bmw now, but well see i leave in 3 weeks. thanx again for the info
LST2
Dec 10, 2006 12:57 PM
baked_beanz
Aug 14, 2005 10:19 AM
swaytec360
Feb 14, 2005 01:29 PM
Jasper
Jan 31, 2005 04:43 PM
