problem with turn signals help!!!!
sorry guys, tried posting this on redpepper.com but knowone would help me there.
the turnsignal/headlight switch on my 86 crx was cracked, so i found one in a junk yard and put it in tonight. now the headlights work fine, but the turnsignals will not work. the fuse is fine, so what could the problem be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_max420 »</TD></TR><TR><TD CLASS="quote">if the turn signals dont work at all, you might need a flasher</TD></TR></TABLE>
what is a flasher?
what is a flasher?
ok, where is it located and what does it look like? also what should i look for to tell if it is broken or not?? thanks alot, this is getting me somwhere
