help with hazards
Old Nov 13, 2005 | 03:34 PM
EJ8chu's Avatar
Default help with hazards
ok my hazards stopped working on my 91 DA...checked all the fuses....whats my problem??
Old Nov 13, 2005 | 04:05 PM
DB8_TEG's Avatar
Default Re: help with hazards (xxsteve803xx)
your signals still work when you turn though? did you happen to check the fuse for the hazard relay?
Old Nov 14, 2005 | 09:07 AM
EJ8chu's Avatar
Default Re: help with hazards (DB8_TEG)
where is that at?? i replaced the fuse underhood and the fuse under the dash...
Old Nov 14, 2005 | 10:52 AM
projectTeG's Avatar
do your turn signals still work? it might be your harzards switch.
Old Nov 14, 2005 | 11:05 AM
Backk InTheDA's Avatar
I hate everything
Default Re: (projectTeG)
I'm having the same problem, and yes, my signals still work, what could it be? When you say hazards switch, you mean the one you press to turn them on correct?
Isn't there a relay specific to the hazards?
Old Nov 14, 2005 | 12:05 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (BuilttB18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuilttB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">I'm having the same problem, and yes, my signals still work, what could it be? When you say hazards switch, you mean the one you press to turn them on correct?
Isn't there a relay specific to the hazards?</TD></TR></TABLE>
Check your fuses, I believe there's one specifically for the hazards. I'll check when I get home.
Old Nov 15, 2005 | 06:51 AM
EJ8chu's Avatar
Default Re: (shamoo)
ok replaced the button...replaced both fuses....blinkers still work...i think there might be a relay for the hazards but where would it be at??
Old Nov 15, 2005 | 07:03 AM
projectTeG's Avatar
Default Re: (xxsteve803xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxsteve803xx &raquo;</TD></TR><TR><TD CLASS="quote">ok replaced the button...replaced both fuses....blinkers still work...i think there might be a relay for the hazards but where would it be at??</TD></TR></TABLE>
under the dash.
Old Nov 17, 2005 | 05:27 AM
EJ8chu's Avatar
i know but what one???
n.o.r.e
Oct 6, 2011 07:07 AM
wseg
Mar 3, 2010 03:35 PM
Lil_Jon
Apr 17, 2007 08:19 AM
EK SQUAD 425
Aug 6, 2006 07:29 AM
ErikDaGenErik
Jan 20, 2003 01:37 AM
