LS vtec question.............oil pump
Old Sep 3, 2004 | 11:20 AM
mrbsponge's Avatar
Default LS vtec question.............oil pump
is it 100% necessary to run a vtec oil pump??? im askin this a little late caus emy friend did NOT change his pump and is bitching about vtec falling out and i think it is due to lack of oil pressure.
he said at 3 grand he can cover up the oil feed line with his finger and block it off completely.............
also he used the front port onhis head for his turbo and burned up his turbo due to lack of oil???????
Old Sep 3, 2004 | 02:43 PM
piles's Avatar
Default Re: LS vtec question.............oil pump (mrbsponge)
Vtec oil pump is a must.
Burning up his Turbo from lack of oil would be right. Get a greddy sandwich plate
Old Sep 3, 2004 | 07:20 PM
mrbsponge's Avatar
whats the price on one of those sandwhich plates
Old Sep 3, 2004 | 07:29 PM
piles's Avatar
Default Re: (mrbsponge)
40-75 I think I have an extra one somewhere
Old Oct 12, 2004 | 08:00 PM
alloysr16s's Avatar
does anyone have an jdm itr oil pump?
Old Oct 13, 2004 | 10:37 AM
98itr0448's Avatar
Default Re: LS vtec question.............oil pump (alloysr16s)
Inline-four.com 126.00 ish shipped.
Old Oct 13, 2004 | 10:51 AM
The Destroyer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloysr16s &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have an jdm itr oil pump?</TD></TR></TABLE>
Im gonna guess that the USDM/JDM oil pump is the same.
Old Oct 13, 2004 | 10:52 AM
98itr0448's Avatar
Default Re: LS vtec question.............oil pump (Vtaaak y0)
yeah, they should be interchangeable. The jdm and usdm itr motors are very similar.
Old Dec 5, 2004 | 02:24 PM
slayersluck's Avatar
Default Re: LS vtec question.............oil pump (LSVtecITR)
i'm going to go ls/vtec with type r oil pump...but do you guyz know if we need a vtec water pump??
Old Dec 5, 2004 | 09:32 PM
2ndgent3g's Avatar
a vtec water pump is good but remember vtec water pump=vtec timing belt
non vtec = non vtec timing belt
not good to use ls water pump
Old Dec 5, 2004 | 09:38 PM
2ndgent3g's Avatar
picked up some info&gt;You 'SHOULD' go with the B16a/B18C water pump as it is superior to the B18a/b pump and will provide more cooling to the now higher revving motor setup. Either way if you use the B16a/B18C pump, then you should use the GSR timing belt. Why? Because the b16/B18c water pumps have more teeth on them, which will cause the LS timing belt to misalign the crank with the respect to the cam gears at TDC
civicman69x
Jul 30, 2007 09:04 PM
civcexcoupeblack
Sep 14, 2003 05:38 PM
lsvtec42
May 18, 2002 01:20 PM
