Oil pump question
Old May 18, 2002 | 11:02 AM
lsvtec42's Avatar
New User
Default Oil pump question
I have a LsVtec motor and i am not getting enough oil pressure off of the back of the block...could I run my vtec line stright from the big plug on the oil pump? should using that spot increase/stabilize my pressure and would running a bigger line that allows for more flow help too? just lemme know thanks...
k
Old May 18, 2002 | 11:50 AM
MrFatBooty's Avatar
Default Re: Oil pump question (lsvtec42)
Which oil pump are you using?
Old May 18, 2002 | 01:20 PM
lsvtec42's Avatar
New User
Default Re: Oil pump question (MrFatBooty)
jdm b16 oil pump(i dont think jdm v. usdm should make a difference) the pump came off the same motor that my head came from and it was in good shape so I assume the pump should be in good shape too...
[Modified by lsvtec42, 5:22 PM 5/18/2002]
Badassbigblock
Feb 17, 2018 01:19 PM
authority1
Apr 9, 2005 06:11 AM
94siturbo
Nov 2, 2003 03:16 PM
sk8rmike
Oct 8, 2003 08:41 PM
