your thoughts on Castrol fromula RS 10W60
Old Dec 6, 2001 | 05:26 AM
austrian type-R's Avatar
Default your thoughts on Castrol fromula RS 10W60
Anybody is using this oil? How do you like it? I want to switch from Castrol SLX 0W30 to RS 10W60. Sometimes my car consumes oil when I drive it hard. I talked to the company which drives the Rs in the cup over here and they are using this oil. So I guess it must be good, or?
Old Dec 6, 2001 | 04:04 PM
1fastGSR's Avatar
New User
Default Re: your thoughts on Castrol fromula RS 10W60 (austrian ITR)
don't just use because someone else does! Use what's recommended for your car. 5w30 or 10w30.
Old Dec 6, 2001 | 04:06 PM
Default Re: your thoughts on Castrol fromula RS 10W60 (1fastGSR)
Thats the point! Everybody says something different.
Old Dec 6, 2001 | 04:47 PM
Cosworth's Avatar
austrian ITR, what kind of races are you running in? If it's endurance race, you would obvious go higher than the factory recommended 5W or 10W-30. I remember people running 15W-40 (?) for track events.
Old Dec 6, 2001 | 04:51 PM
Warren's Avatar
Wrong-Way Wang
Beware thicker oil. Make sure you have a decent oil temp gauge if you're going to try something thicker, as thicker oil may actually run hotter than thin.
Me? I run 5W-30 and 10W-30 in my ITR. So what if it burns some off? Replace it.
Warren
Old Dec 6, 2001 | 04:53 PM
Big Phat R's Avatar
First, run a bigger/better radiator. If you still are burning oil get an external oil cooler. If your motor is burning oil - it's running too hot. Changing your oil viscosity is attacking the problem from the wrong end. Use what Honda recommends.
Old Dec 11, 2001 | 11:46 PM
Default Re: your thoughts on Castrol fromula RS 10W60 (Big Phat R)
3 times in a your Drag racing
5 times in a year Auto X
Driving about 1/2 hour with over 7000rpm in 5th gear on the German Autobahns, oil is burning here!!!!
[Modified by austrian ITR, 12:46 AM 12/12/2001]
Old Dec 12, 2001 | 12:48 AM
orca's Avatar
I heard, that the 10 W 60 can cause problems with the VTEC-System. The oilpressure that regulate the VTEC is not right, if you use 10 W 60. I talked to one guy of Rikli Motorsport. They drive with two ITR in the german DTC-series. They use 0 W 40 oil. These Interas got 240 hp whithout any turbos or superchargers. They shift at 9'800 rpm. If 0 W 40 oil is perfect for these hard conditions, i think you can use it whithout any problems.
greetz
orca
Old Dec 12, 2001 | 06:16 AM
Yell00ITR's Avatar
Default Re: your thoughts on Castrol fromula RS 10W60 (orca)
You want to use an oil with as little variance between the "cold" and "hot" ratings. I would be very scared of using any oil with a 50 point spread. Not to mention the ITR engine does not get hot enough to justify a 60 weight oil, unless you are pushing 20+ lbs of boost or something
Old Dec 12, 2001 | 06:26 AM
Default Re: your thoughts on Castrol fromula RS 10W60 (Yell00ITR)
ORCA! Nice too see you here! What specs of cams do they use when they shift at such high rpms?
Then I guess i stick better with the 0W30 Castrol SLX.
Old Dec 12, 2001 | 01:47 PM
nsxtcjr's Avatar
New User
When everybody says something different, just use what the manual tells you to use.
That's why I use 5W30.
bonSI
Aug 20, 2008 01:51 PM
TimeRacer
42
Jun 7, 2005 09:17 AM
Civic44
13
Oct 21, 2004 06:22 AM
itr449
Nov 6, 2002 12:14 PM
turbosi92
Jul 3, 2002 11:27 AM
