Where to buy best funnel for tranny fluid change?
I know you need a long necked funnel to change your tranny fluid properly, does anyone here recommend a certain brand/type or have any suggestions of where i should go to find one the perfect size? What do you use?
If you fill it via the VSS hole, you can just use any cheapo long slim funnel. I filled mine via the VSS hole, even though I have a tranny funnel w/ long clear tube and cap on the end, but it was still alot easier because the tube would sometimes kink up when I tried to get it in the filler hole. Also my tranny funnel has a shutoff right before the clear tube, and the top piece has measuing marks on it, so you can measure out about 2.5 quarts when filling and not even have to remove the filler plug.
i bought a little syphoning hose from canadian tire, it was $4, just stick one end in the bottle of fuild, the other end in the filler hole and squeeze the pump, so easy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">I use about a 3ft length of 1/2" clear hose with a small funnel and fill through the VSS.</TD></TR></TABLE> this is probably the best way to do it...just make sure you have someone help you watch the hole for when it fills up
If you just go to Advance Auto Parts, they have the funnels like PatrickGSR94 was talking about w/the clear hose and measuring part at the top....I like those funnels!
I made my own using a water bottle with the bottom cut off and I taped a 2.5' clear hose i had in the garage to the neck. It worked perfectly, I even saved it for a week to change my gf's.
Seedc2
Aug 6, 2003 05:59 PM
stRtypR25
Jan 20, 2002 08:21 AM
