what spark plugs for H22 turbo?
Old Dec 6, 2001 | 04:16 AM
Boosthead's Avatar
Default what spark plugs for H22 turbo?
What spark plugs should I run in my turbo H22?
Old Dec 6, 2001 | 05:46 AM
Canuk_SiR's Avatar
Default Re: what spark plugs for H22 turbo? (Boosthead)
Try some iridium plugs. Those things are very good for boost. Get some with a gap of .035" to 0.039". That should be good enough on a boosted motor
Old Dec 6, 2001 | 06:23 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: what spark plugs for H22 turbo? (Canuk_SiR)
I thought the good gap was like .28-.34 ?
Old Dec 10, 2006 | 05:18 PM
djnikko's Avatar
Default Re: what spark plugs for H22 turbo? (ForcedAccord)
Holy thread revival batman
Does anyone know a part number for NGK or DENSO iridium plugs to use on a built (9:0:1) & boosted H22 engine?
Old Dec 10, 2006 | 05:29 PM
Mikey3000's Avatar
Default Re: what spark plugs for H22 turbo? (djnikko)
lol. my tuner put NGK BCPR7ES in mine. i made 505 whp. its just a regular plug 1 temp range colder than stock.
Old Dec 10, 2006 | 06:10 PM
djnikko's Avatar
Default Re: what spark plugs for H22 turbo? (Mikey3000)
Ive got these already. Looks like i'll go with those then
Do you think the iridium plugs would be an upgrade as such? Is there any comparrison threads anyone is aware of
Old Dec 10, 2006 | 06:17 PM
Mikey3000's Avatar
there's prolly very little difference if any at all between spark plugs as far as performance goes. you can get a lot of info from ngk's website about the different plugs.
Old Dec 11, 2006 | 03:39 PM
djnikko's Avatar
Old Dec 11, 2006 | 04:31 PM
kornerk12's Avatar
i remember hearing awhile back that you should only run coppers with forced induction. How true is that ?
Old Dec 11, 2006 | 04:54 PM
h22sedan's Avatar
Default Re: what spark plugs for H22 turbo? (kornerk12)
NGK BCPR7ES
Would those be good even for a stock block turbo setup?
I don't want to just go making an assumption that could lead to a problem during tuning.
Old Dec 11, 2006 | 04:56 PM
mrbh22's Avatar
Default Re: what spark plugs for H22 turbo? (h22sedan)
denso iridum ik22. used them on mine woked out great
22boost
May 18, 2007 12:21 PM
Lenne
Nov 17, 2005 06:04 PM
afterburners
May 28, 2004 01:40 PM
