Hey guys what do think of this build plan?
Im trying to have a good daily driven reliable 00 Civic Si that can outrun most mustangs and camaros. I have a plan in my head of stuff I want in the future and stuff I already have. Just trying to piece it together and see if you guys recommend anything else. This is all for the stock B16a2.
AEM V2 (have)
STR 70 mm TB ( in tha garage)
Skunk2 Intake Manifold (in tha garage)
Hondata Gasket (future)
Skunk2 Stage 2 cams(garage)
Skunk2 retainers (garage)
" " valve springs (garage)
" " Valves (garage)
" " Adjustable cam sprockets (garage)
Sun auto hypergrnds (have)
Nology wires w/capicitors(have)
NGK iridiums IX (have)
Port Polish head (future)
Hondata S200 (future)
Header im debating to save and get TODA or JDM DC 4-1(future)
Car sound 2.5 hi flo (future)
Kteller 2.5 mandrel bent (future)
ES one or Tanabe muffler (future)
Koyo Radiator (future)
Mugen cap (have)
Mugen thermostat (future)
STR fuel rail w/regulator (future)
AEM High flo fuel filter
Energy suspenaion Eng mounts (future)
Suspension wise
Skunk2 Coilovers (have)
Front camber kit (have)
Rear camber kit (future)
KYB AGXs (future)
Mugen Front rear tie bars (future)
skunk2 rear lower tie bar (future)
Energy suspension inserts (future)
Wheels
Cant decide Volk TE37s, MF8s or gab sports (all 16 by 7)
with 205/45/16 Azenis.
What do you guys think, yays or nays ? Let me know please.
AEM V2 (have)
" " Valves (garage)
Mugen cap (have)
Suspension wise
KYB AGXs (future)
Wheels
Personally I think with just that list of parts on a stock bottomed B16 in a relatively heavy 2000 SI will yield a car with a lot of money invested that will lose to most V8 stangs. Personally if you wanna stay with the 1.6 liter, you're gonna need to bump compression a decent amount to get the power you want and make use of those cams. As reliability seems very high on your list, I would suggest ditching the B16 bottom end or complete longblock and going with a GSR long or shortblock. The extra torque of the bigger engine will do wonders.
The 70mm TB will probably be too large for that application until you finish the head and build the bottom end. You would probably loose low end torque. You may want to stick to a 65mm or 68mm TB. Just a suggestion.
exactly you need to get higher compresion pistons.
you gotta build the head and bottom end eventually. Cause sooner or later something will give with those agressive parts
From: chillin in that city called queen creek, but homes the atl
what is this your christmas wish list just by all the stuff u are planning on buying i can tell u know nothing about your car. hell do even own a si. dude u got too research first before u go out and buy all this **** just too steal be slow. u got to research and plan out this projects just so u don't waste money and u know what works
You're not specifying anything about this build. You are just listing parts.
Start with compression, valve type, size, duel/single springs? etc. I personally think you 're stretching the truth on your parts list, but maybe not, give us more details.
like these guys already said, you cant just buy parts and piece them together. you have to talk to builders and tuners and make sure that all these parts work together for the highest possible hp numbers. your tire and suspension set-ups sounds really good, but some of those parts will be useless without higher COMPRESSION. built motors HAVE TO HAVE COMPRESSION.
by the way, your stock civic si does NOT outrun most mustangs and camaros.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22coupe »</TD></TR><TR><TD CLASS="quote">Personally I think with just that list of parts on a stock bottomed B16 in a relatively heavy 2000 SI will yield a car with a lot of money invested that will lose to most V8 stangs. Personally if you wanna stay with the 1.6 liter, <U>you're gonna need to bump compression a decent amount to get the power you want and make use of those cams.</U> As reliability seems very high on your list, I would suggest ditching the B16 bottom end or complete longblock and going with a GSR long or shortblock. The extra torque of the bigger engine will do wonders. </TD></TR></TABLE>
ALL very good advise
b16powwer
28
Oct 17, 2004 10:35 PM
Electron Si
12
Feb 18, 2004 02:36 PM
