lsvtec question..??
Old Sep 2, 2004 | 09:06 PM
sohcfreak's Avatar
Default lsvtec question..??
okay..i been searching for lsvtec answer and found none....can any body help me out...? heres the setup im building.(budget).
b18b block oversized
type r .25 oversized pistons
shotpeened ls rod
arp rod bolts
gsr oil pump
b16 water pump
b16 timing belt
b16a head
pnp head
reseated stock valves
milled.05 or .10 ...?
CTR IN CAM
GSR EX CAM
STOCK B16 VALVE SPRINGS
aem cam gears
aem fpr
rail
stock b16 intake manifold
obd-1
p28
cable b16 tranny
Will i have clearance if i mill the head .5 or .10 with the ctr cam..?
What rpm range is safe with stock b16 valve springs with ctr cams or would it be safe to upgrade valve springs..?
How much can i advance timing...?+2,-2...1,1..+1,-1...etc?without dynoing.!
what size injectors..? i have stock b16 obo..!
Do I need to upgrade fuel pump!
let me know any body out there lsvtec guru or has same setup as this one....i want everyones opinion..let me know
Old Sep 3, 2004 | 06:37 AM
SiKnezzALLmotor's Avatar
Default Re: lsvtec question..?? (sohcfreak)
hmmmm..
Old Sep 3, 2004 | 06:38 AM
sohcfreak's Avatar
morining bump
Old Sep 3, 2004 | 11:36 AM
sohcfreak's Avatar
noon bump
InTheLBC20
Dec 18, 2010 02:40 AM
sohcfreak
Sep 5, 2004 10:40 AM
94CivSi
Apr 7, 2003 07:59 AM
-16V-
Nov 19, 2002 10:20 PM
