causes of low oil pressure?
Old Sep 2, 2004 | 08:33 PM
pissedoffsol's Avatar
25 Year Member
Default causes of low oil pressure?
welp, once my car is warm, i have next to no oil pressure at idle.
at WOT, i'm hitting about 4 bars... under 60 psi. it should be more than that.
As a result, i'm not switching lobes, as the pressure switch isn't seeing what it needs.
pan = moroso
pickup = moroso
windage tray = stock gsr
oil pump = stock gsr
any ideas?
Old Sep 2, 2004 | 09:20 PM
StyleTEG's Avatar
Default Re: causes of low oil pressure? (pissedoffsol)
too wide clearances on your bearings.
Old Sep 3, 2004 | 12:28 PM
25 Year Member
Default Re: causes of low oil pressure? (StyleTEG)
other ideas?
Old Sep 3, 2004 | 01:51 PM
kgibson16's Avatar
bad bearings or bad oil pump
Old Sep 4, 2004 | 06:07 AM
JdmEKCivic's Avatar
Is the guage working properly, also chk your oil level
Old Sep 4, 2004 | 03:44 PM
25 Year Member
Default Re: (Jdm EK Civic)
i have abotu 6.5 qts in the pan.
the gauge is a top of the line greddy warning meter.
more over, even if the gauge was wrong- why am i still not getting enough pressure to switch lobes? the reasoning is fouled.
next.
Old Sep 4, 2004 | 10:41 PM
Jago's Avatar
OIl pressure is determined by bearing clearance.
Old Sep 5, 2004 | 08:43 AM
hondaguyef's Avatar
Default Re: causes of low oil pressure? (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">OIl pressure is determined by bearing clearance.</TD></TR></TABLE>
At what clearance does the pressure start to drop? How loose?
pissedoffsol,
What are your clearances @ right now?
Phil
Old Sep 7, 2004 | 02:12 PM
25 Year Member
Default Re: causes of low oil pressure? (hondaguyef)
damned if i know... jeff at IB built the block, which was frist built for some dude in cali on here, who i then bought the block from. tracing it back is going to be near impossible.
i'm at the point where
A- **** oil pressure. ahve fun with it till it blows up.
B- part it out
C- spend all more kinds of money on this damn car
and i just don't know what to do anymore with it.
Old Sep 7, 2004 | 05:14 PM
PHiZ's Avatar
One of the big reasons that people are reporting (in searches) is having the teflon tape clogging one of the fittings on the orifices
-PHiZ
Old Sep 7, 2004 | 06:44 PM
25 Year Member
Default Re: causes of low oil pressure? (PHiZ)
teflon tape where?
on what orifice?
Old Sep 7, 2004 | 06:54 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">teflon tape where?
on what orifice?</TD></TR></TABLE>
where your gauge is hooked up to.
I would just go get a $10 mech. oil pressure gauge at the parts store to have a 2nd opinion on the pressure.
check vtec oil pressure on the port by the sol. it should be 50 psi+
Old Sep 7, 2004 | 07:01 PM
HybridKOOP's Avatar
Default Re: causes of low oil pressure? (mmuller)
Just sell me everything. I'll take care of it all.
Old Sep 18, 2004 | 04:34 PM
JdmEKCivic's Avatar
What about your oil pump your sure it not clog and is working properly
Old Sep 18, 2004 | 05:34 PM
SkRiBLaH's Avatar
Default Re: (JdmEKCivic)
oil sump too close the bottom of the oil pan. thus not picking up enough oil.
i would check that.
Old Sep 18, 2004 | 11:35 PM
wHOAlly's Avatar
Default Re: (SkRiBLaH)
if your hittin those psi numbers, and your have been driving on it for a while, it would be safe to say your bearings are toast, and your cams might be wearing into the head causing scarring, same goes wtih the pistons and cylinder walls.
dont ask how i know
Old Sep 19, 2004 | 08:44 AM
asubennett's Avatar
Default Re: (Sp00n'd Supra)
What oil filter are you running. Reason why I ask is I have seen oil pressure differences of 10-15psi from a FRAM/ whatever autozone replacement filter they have from an OEM honda filter. Those Honda fitlers are so tiny and skinny for a reason.
Old Sep 21, 2004 | 04:00 PM
25 Year Member
its a mroso pick up and pan. i would think they would make it fir right, no? or at least have other people here have problems with them....
the car hasn't seen more than 10 miles tops... its has never fully run correctly.
filter is mobil 1.
think theres a big difference cuz i have my guage off my GEM sandwhich adapter?
Old Sep 21, 2004 | 04:01 PM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote"> where your gauge is hooked up to.
check vtec oil pressure on the port by the sol. it should be 50 psi+</TD></TR></TABLE>
i bought a sunpro tonight... but all my lines are wrong for it, so i have to redo the whole hting toorrow whern theres still light outside.
Old Sep 21, 2004 | 04:30 PM
wHOAlly's Avatar
Default Re: (pissedoffsol)
i had my greddy sensor off the gem adaptor too, read the psi fine.
Old Sep 21, 2004 | 04:37 PM
25 Year Member
:-/ thats not what i wanted to hear.
what oil are you using?
Old Sep 21, 2004 | 06:36 PM
UnKnownUser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kgibson16 &raquo;</TD></TR><TR><TD CLASS="quote">bad bearings or bad oil pump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic &raquo;</TD></TR><TR><TD CLASS="quote">What about your oil pump your sure it not clog and is working properly</TD></TR></TABLE>
Oil pump bro
Old Sep 21, 2004 | 07:10 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">:-/ thats not what i wanted to hear.
what oil are you using?</TD></TR></TABLE>
mobil 1 10-30, after this rebuild, im gonna stick to the thicker stuff, 0-40 or 15-50, somethign like that, the high heat of the turbo system makes the oil like water
last thing u wanna hear, but pull the bitch apart while ur ahead so u can diagnose the prob man, trust me, u will regret it if u dont
Old Sep 21, 2004 | 07:34 PM
fourthgenhatchB17's Avatar
I say get a new oil pump and see what happens. That looks like the cheapest thing to do. Dont think your oil weight, filter, or gauge is the problem. You must be getting a CEL because the vtec oil psi switch is not seeing the psi it needs?
Old Sep 21, 2004 | 07:42 PM
93lsd's Avatar
mainly sounds like bearings being too loose
