Questions about Knock Sensor and 2nd O2 Sensor/bung
For the knock sensor will it cancel out the Knock sensor code if i just connect the pinout to a ground? and will it be safe?
Also for the 2nd O2 sensor bung with the AN-R header has a bung welded but i was wondering if it mattered where i place the 2nd bung?
Thanks in advance
i think these are the things that are causing my CEL problems
Thanks in advance
Thanks in advance
Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3bluegsr »</TD></TR><TR><TD CLASS="quote">For the knock sensor will it cancel out the Knock sensor code if i just connect the pinout to a ground? and will it be safe?</TD></TR></TABLE>
You can, but you need to put some resistance to it and not just ground the wire or it'll throw the code right away. Use a 10K ohm resistor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3bluegsr »</TD></TR><TR><TD CLASS="quote">Also for the 2nd O2 sensor bung with the AN-R header has a bung welded but i was wondering if it mattered where i place the 2nd bung?
Yes, you can weld a nut onto the header and screw in the 2nd O2 sensor. The O2 sensors are not heated so you need then to be hot in order to send a good signal to the ECU. Thus, place the O2 bung up on the primaries and not on the downpipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
10ohm 10watt resistor will be alright????
Yes, you can weld a nut onto the header and screw in the 2nd O2 sensor. The O2 sensors are not heated so you need then to be hot in order to send a good signal to the ECU. Thus, place the O2 bung up on the primaries and not on the downpipe.</TD></TR></TABLE>
hmmm i have the 1st O2 connected on the downpipe cause that is where it was when i got the header is that ok?
.</TD></TR></TABLE>
10ohm 10watt resistor will be alright?????</TD></TR></TABLE>
10K = 10,000
hmmm i have the 1st O2 connected on the downpipe cause that is where it was when i got the header is that ok?</TD></TR></TABLE>
With a PR3 or PW0, the O2 sensors need to be hot in order for the ECU to read them properly so placing them up on the primaries is required. I had them on the downpipe before and runs like **** until the car warms up. Look at a stock B16 cast iron exhaust manifold - the O2 sensors are placed up on the primaries.
10K = 10,000
ok thanks i'll def try out that resistor thing thanks... also i'm loving my HCP mounts and linkage tahnks!
racingant
Sep 10, 2005 05:34 PM
