RSX-S Oil filter change mess... sick of it.
Old Sep 2, 2004 | 12:31 PM
RevenantAE's Avatar
Default RSX-S Oil filter change mess... sick of it.
Every time I pull the oil filter from the RSX it spills oil all over creation. My workaround for this is to place a plastic bag under the thing when I pull it, but that's not fool-proof (bag + hole = mess). I'm thinking of relocation the filter to make this less of a PITA. Anyone done this yet?
Old Sep 2, 2004 | 12:41 PM
DC5ITR329's Avatar
Default Re: RSX-S Oil filter change mess... sick of it. (RevenantAE)
I've heard this lowers your oil pressure.
Old Sep 2, 2004 | 12:55 PM
RevenantAE's Avatar
Default Re: RSX-S Oil filter change mess... sick of it. (aznbo1626)
Hmm....... I wouldn't think it would... I guess it would depend on the lines you used.
Old Sep 2, 2004 | 03:13 PM
Gerhard_001's Avatar
Why don't you spray the area with brake cleaner after you are done and wipe the rest with a rag. the brake cleaner breaks down the oil and it evaporates quickley.
Old Sep 2, 2004 | 04:02 PM
rsxmachine's Avatar
get one of those funnels with a flexible hose on it, they only cost a couple bucks at any autoparts store. cut a u-shaped section out of it so you basically have half a funnel but with the hose still attached. break the filter loose, then put the half-funnel underneath it to catch the mess as you remove the filter (with the hose leading to a drain pan underneath of course).
Old Sep 2, 2004 | 05:11 PM
RevenantAE's Avatar
Default Re: RSX-S Oil filter change mess... sick of it. (Gerhard_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you spray the area with brake cleaner after you are done and wipe the rest with a rag. the brake cleaner breaks down the oil and it evaporates quickley.</TD></TR></TABLE>
Well, the issue is to make it so there is nothing to clean up. Besides, cleaning the garage floor is easy... cleaning the different suspension and frame parts it drips on is harder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxmachine &raquo;</TD></TR><TR><TD CLASS="quote">get one of those funnels with a flexible hose on it, they only cost a couple bucks at any autoparts store. cut a u-shaped section out of it so ...</TD></TR></TABLE>
That's a damn good suggestion... I'll give that a shot and post back here how well it works.
Old Sep 2, 2004 | 06:07 PM
khunt0012's Avatar
Meat Robot Invisible
What we do at Acura is place a junk towel/cloth on the subframe directly underneath the filter. This way all you have to wipe down is the CV joint + boot. This obviously works alot better if you've got a hoist, but will still do the job on the ground.
Old Sep 3, 2004 | 07:06 AM
slowdc5's Avatar
How bout payin a little more $$$ and have it done at a shop.
Hrs/Mins of ur time+Oil everywhere=PITA
$$+shop=Priceless
Old Sep 3, 2004 | 07:09 AM
B18CXr's Avatar
Default Re: RSX-S Oil filter change mess... sick of it. (honda004)
just use a "Jumbo" Jack in the Box drink cup, cut the top off from the lip VERTICALLY down half way, then around the circumference half way, then VERTICALLY back up to the lip.
Old Sep 3, 2004 | 08:04 AM
RevenantAE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda004 &raquo;</TD></TR><TR><TD CLASS="quote">How bout payin a little more $$$ and have it done at a shop.
$$+shop=Priceless</TD></TR></TABLE>
After an Eagle dealer left the center differential on my AWD DSM attached with 1 frigggen bolt, I realized I can't trust anyone to work on my cars that isn't me. It's kind like the old "never let ANYONE borrow your motorcycle" saying.
Old Sep 3, 2004 | 08:35 AM
johnkimble's Avatar
word, i get mine done at the shop. 15 bucks for an oil change at the honda dealer is more than worth it.
Old Sep 3, 2004 | 09:22 AM
wdskuk's Avatar
I rather do the work myself and save the money for other things. I could use the money for lets say better oil.
Old Sep 4, 2004 | 03:21 PM
PHiZ's Avatar
Yeah, great idea. Because the shop gives two ***** about dripping oil on your car, but I'm guessing you've never been underneath it, so you wouldn't know.
-PHiZ
Old Sep 4, 2004 | 04:33 PM
DC5ITR329's Avatar
Default Re: (wdskuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk &raquo;</TD></TR><TR><TD CLASS="quote">I rather do the work myself and save the money for other things. I could use the money for lets say better oil.</TD></TR></TABLE>
Mobil 1 and a HAMP filter
Old Sep 5, 2004 | 12:09 AM
jdmeng's Avatar
what happens if theres left over oil on the subframe or cv boot? just wondering.. . i always try to clean it up but i might miss spots
Old Sep 5, 2004 | 09:47 AM
RevenantAE's Avatar
Default Re: (yOo_JeAn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOo_JeAn &raquo;</TD></TR><TR><TD CLASS="quote">what happens if theres left over oil on the subframe or cv boot? just wondering.. . i always try to clean it up but i might miss spots</TD></TR></TABLE>
1: the CV boot throws it all over the underside of your car.
2: dirt combines with the oil to leave a wonderful looking sludge under your car. It's fun to clean AND looks yummy
Old Sep 5, 2004 | 02:07 PM
jimmyjames's Avatar
Default Re: RSX-S Oil filter change mess... sick of it. (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
Good call.
brucepick
May 2, 2010 02:54 PM
1LowSol
31
Feb 22, 2009 05:55 PM
digdug18
30
Sep 13, 2005 05:12 PM
TeGGY_LS
Aug 6, 2004 01:16 PM
nd8ch
16
Apr 22, 2003 12:53 AM
