door hinges
Old Sep 2, 2004 | 10:19 AM
REVS-2-9K's Avatar
Default door hinges
how hard are they to replace i think mine are sagging. 1988 crx
Old Sep 2, 2004 | 10:22 AM
Home Skillet's Avatar
Default Re: door hinges (REVS-2-9K)
Crap, mine have been sagging too for the past 5yrs. This is one of those things I've meant to as HT about but always forget when I'm in front of the computer. Anyways, bump, I'd like to know too.
Old Sep 2, 2004 | 11:55 AM
4drEF's Avatar
Keyboard Humorist
Not too hard.
Remove the front fender and you will have access to all the bolts.
Old Sep 2, 2004 | 12:02 PM
Tyson's Avatar
Default Re: door hinges (4drEF)
you can remove the door and hinges without removing the fender. take off the pin to get more space between fender and door. a box end wrench helps for some of the bolts too.
Old Sep 2, 2004 | 12:26 PM
EFSiR's Avatar
mine are going as well... What is it that I should be replacing? Is it just the pin or the entire ASSMBY?
Old Sep 2, 2004 | 02:16 PM
NCRXSi's Avatar
Default Re: door hinges (EFSiR)
Its not that bad if you have someone to help you. The biggest pain in the *** is trying to get it lined up again. Before you remove the old hinges, mark where they were located and when you install the new ones hopefully the door will line up. You don't have to remove the fender but if you can't get the door to line up by adjusting the door from the doorside hinge, you'll at the least have to remove the inner fender well to get to those bolts to make your adjustments.
Unplug your door wiring harness, remove the pin from the limiter (or whatever the hell that rod is called..lol), remove the bolts from the doorside hinge. Remove the door and then you can access the other hinge bolts.
coupekaaos
Jul 4, 2011 07:36 AM
El_Jdm_Junky
Apr 19, 2009 07:46 AM
steerh67
Feb 16, 2008 06:30 PM
bg-33p
Mar 26, 2007 10:27 AM
fackyou
Aug 25, 2006 10:03 AM
