gsr was flooded, need to know what i can salvage off my car...
ok, my car was under liek 7 feet of water for hours on monday, i know its totalled, but when i get it back, i wanna know which parts i can still use and which parts need to be replaced, im gonna hopefully get ANOTHER gsr, and swap the good parts into THAT.
some parts i know are fine to be reused, but some im not sure about and wanna get second opinions.
so anyway, heres the list of stuff which i need to know if still good...
1. jdm LSD out of a ctr i think
2. act HD pressure plate
3. act organic street/strip disk
4. carsound catalytic converter
5. magnaflow muffler
6. magnacore 9mm spark plug wires
7. tokico blue struts
Thanks in advance for the help guys.
I would drain/flush/refill the engine and fuel tank do the tranny too while your at it. pull the plugss and put some carb cleaner into each cyl. and turn it over a few times with no plugs and then re-install. I work on turf equipment and i've had guys flip mowers into lakes and ponds and most of the time the electronics are all ok, and they do sit for a few hours until a wrecker gets there to pull it out. you may want to do it asap so no rust starts occuring and fully lube/re grease your chassi. I' would go ahead and flush your p.s. and clutch fluid while your at it. hopefully all will be well. and if you decide to scrap your engine/tranny. sell me the tranny cheap, i'm but a poor white boy with more advice than money.
donkeykong243
12
Nov 16, 2012 01:38 AM
aye5882
Mar 10, 2008 09:17 AM
Johnnym3
Nov 18, 2007 03:16 PM
