building hp and torgue
advance the timing a couple of degrees to give better top end - get an intake, header, exhaust, and put the suspension on it. get stiffer springs and adjustable shocks. that way when you step on the gas, the *** of the car doesn't fall back so much. if you have or know anyone who has the time and capability to turn your flywheel and lighten it, that will control and give you more hp too. just don't lighten too much or you will lose low end torque and hp. also, when you put it back together, make sure your clutch and flywheel are balanced, or you will have more serious problems.
you have a great car - enjoy it!
