b18c-r swap into crx...shopping list?
Old Sep 1, 2004 | 09:25 PM
SpeedMonkeyRacing's Avatar
Default b18c-r swap into crx...shopping list?
ok, anyone ever done the whole complete hydro/cable conversion w/ the jdm b18c-r motor? i have a complete swap w/ the hasport conversion kit...i'm planning to convert to obd1 w/ s200 hondata. however, i dunno if i'll be able to use the b18c dizzy?
Jeff-
Old Sep 1, 2004 | 10:20 PM
eda6's Avatar
Default Re: b18c-r swap into crx...shopping list? (JustJeff)
Use an obd 1 dizzy from a b-series motor.
Old Sep 1, 2004 | 11:29 PM
Fobtions's Avatar
Default Re: b18c-r swap into crx...shopping list? (eda6 hb)
u can use the obd2 distributor.........
just repin color for color.
Old Sep 1, 2004 | 11:54 PM
hahagasdcrx's Avatar
Default Re: b18c-r swap into crx...shopping list? (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">Use an obd 1 dizzy from a b-series motor.</TD></TR></TABLE>
You can go that route.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">u can use the obd2 distributor.........
just repin color for color. </TD></TR></TABLE>
Cheaper route ( you dont have to buy the obd1 dizzy)
Old Sep 2, 2004 | 04:52 AM
Fobtions's Avatar
Default Re: b18c-r swap into crx...shopping list? (hahagasdcrx)
actually thw wiring goes like this for the distributor
obd2 obd1
blue blu/grn
red wht/blu
green orn/blu
Blk wht
wht blu/yel
yel org
yel/grn yel/grn
blk/yel blk/yel
Old Sep 2, 2004 | 05:36 AM
Charlie Moua's Avatar
damn yo you need to search.
i have a similar setup for my ef.
yes you use gsr distributor. just make sure when doing the obd1 conversion you double check all wiring.
Old Sep 2, 2004 | 05:25 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">actually thw wiring goes like this for the distributor
obd2 obd1
blue blu/grn
red wht/blu
green orn/blu
Blk wht
wht blu/yel
yel org
yel/grn yel/grn
blk/yel blk/yel</TD></TR></TABLE>
You can match up the wires like this using the OBDII engine harness. Or you can simply match by color using the wires on the distributer itself. For whatever reason, the wires on the distributer itself are just the normal colors.
Old Sep 5, 2004 | 09:02 PM
Default Re: b18c-r swap into crx...shopping list? (StorminMatt)
now...how do you solve the vss problem? ef's are using mechanical vss and the new hydra trans has electrical vss. how do i hook up the electrical vss so that it won't throw a code?
Jeff-
Old Sep 5, 2004 | 09:23 PM
daidilus's Avatar
umm swap in a cable vss...or a newer cluster
Old Sep 5, 2004 | 09:56 PM
HandCommand's Avatar
I have one of the "first" production run of the HaSport Hydro EF kit in my CRX running a 98+ spec JDM TYPE R with 4.7 FD LSD in my area.
Do a search and you will find an extensive write up about the kit and feedback from others who have tried it.
I dont know if HaSport has offered this yet, but make sure the 90-93 Integra rear tranny bracket you use gets the 2 lower holes drilled out bigger to accept the bigger 19mm bolts that the HYDRO tranny uses. Make sure you get some bolts that are shorter or at least use spacers to prevent them from bottoming out in the tranny case.
As mentioned above, in regards to your mechanical speedo, just one over to your hydro tranny.
I give you props for converting your set-up to OBD1 and Hondata. I've seen some peeps running the "R" motor in their Hybrid CRX's using the OBD0 distributor and PWO or PR3 ecu. Little do they know they are limiting their "R" motor with the OBD0 electronics.
Those OBD0 distributors tend to crap out easily also and are over a decade old. Plus, they are rare to find for a good price.
Most, if not all hybrid EF hatches or CRXs that come out of my shop get converted to OBD1 from the get-go. It will pay off in the long run.
Old Sep 6, 2004 | 11:43 AM
Default Re: b18c-r swap into crx...shopping list? (HandCommand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandCommand &raquo;</TD></TR><TR><TD CLASS="quote">I have one of the "first" production run of the HaSport Hydro EF kit in my CRX running a 98+ spec JDM TYPE R with 4.7 FD LSD in my area.
Most, if not all hybrid EF hatches or CRXs that come out of my shop get converted to OBD1 from the get-go. It will pay off in the long run. </TD></TR></TABLE>
thank you for the reply and the props! However, I need to know if its possible to rewire the alternator (and the color code).
Now i see the wiring for obd 2 to 1 wiring but what about obd 0 to 1 wiring for dizzy?
Jeff-
Old Sep 6, 2004 | 01:11 PM
Fobtions's Avatar
all u gotta do is swap the lil circuit off your obd0 onto the new alternator.
heres a pic.
Old Sep 6, 2004 | 08:39 PM
blockhondab18c5's Avatar
I'm one of the unfortunate people running a c5 obd o in my 90 si what do i need to go obd1???????? Thanks
Old Sep 6, 2004 | 09:58 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: b18c-r swap into crx...shopping list? (blockhondab18c5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blockhondab18c5 &raquo;</TD></TR><TR><TD CLASS="quote">I'm one of the unfortunate people running a c5 obd o in my 90 si what do i need to go obd1???????? Thanks</TD></TR></TABLE>
I did just that! I got a newer and rare obd1 pr3 ecu, distrbutor, and a frog engineering harness adaptor. You will also need a single 4 wire o2 sensor to run to the harness for the ecu to funtion correctly.
Old Sep 6, 2004 | 10:36 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">all u gotta do is swap the lil circuit off your obd0 onto the new alternator.
heres a pic.
Dang...its just a straight swap eh? I have a 00 SI B16 alternator sittin in the garage. I can swap my old obd-o board thing on to that one and im good to go?
Old Sep 6, 2004 | 10:41 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
You can match up the wires like this using the OBDII engine harness. Or you can simply match by color using the wires on the distributer itself. For whatever reason, the wires on the distributer itself are just the normal colors.</TD></TR></TABLE>
Exactly.
The wires in the harnesses are always completely ******* different than the ones on the distributor... stupid Honda. Just match wire for wire on the distributor. Should be all the same.
Old Sep 7, 2004 | 04:29 AM
ef8powr91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustJeff &raquo;</TD></TR><TR><TD CLASS="quote">ok, anyone ever done the whole complete hydro/cable conversion w/ the jdm b18c-r motor? i have a complete swap w/ the hasport conversion kit...i'm planning to convert to obd1 w/ s200 hondata. however, i dunno if i'll be able to use the b18c dizzy?
Jeff-</TD></TR></TABLE>Im doin the EXACT same setup in my rex!
Old Sep 7, 2004 | 10:24 AM
Fobtions's Avatar
Default Re: b18c-r swap into crx...shopping list? (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
Dang...its just a straight swap eh? I have a 00 SI B16 alternator sittin in the garage. I can swap my old obd-o board thing on to that one and im good to go? </TD></TR></TABLE>
YES sir. i try to tell people not to make a big deal about the alternator. cause it all interchanges.
Old Sep 7, 2004 | 01:39 PM
YES sir. i try to tell people not to make a big deal about the alternator. cause it all interchanges. </TD></TR></TABLE>
to you. Thanks.
Old Sep 7, 2004 | 01:50 PM
Fobtions's Avatar
no problemo!
Old Sep 13, 2004 | 05:33 AM
now here's a new question..
ect (engine coolant temp) code. i know that the 88-91 b/d motors have ect and the thermal switch in two different spot. how do you get rid of that?
Jeff-
Old Sep 13, 2004 | 09:13 PM
anybody? nobody?
Jeff-
Old Sep 13, 2004 | 09:56 PM
Rywire's Avatar
Just add the plug, you will need to extend the wires a bit.
Old Sep 13, 2004 | 09:58 PM
Fobtions's Avatar
Default Re: b18c-r swap into crx...shopping list? (droppedcrxsi)
yep just extend that plug on the back of the block, the one with the dual bullet style connectors. all the way to the water neck.
Old Sep 14, 2004 | 06:12 AM
ok..and what about the one that was suppose to plug onto that water neck?
i tried plugging both and i still get ECT code
Jeff-
Wheelman-CZ
Aug 12, 2007 01:53 AM
russianswty
Oct 16, 2006 02:33 PM
immikejones
Sep 3, 2005 07:15 PM
Power Rev Racing
Jul 27, 2005 05:12 PM
yoyoyo
May 23, 2003 04:06 PM
