d15b oil eater
Old Sep 1, 2004 | 08:19 PM
301am's Avatar
Default d15b oil eater
k my d15's burning oil i took the plugs out to check compression..i have oil in cylinders 1,3,4 and cyl 1=200psi, 2=200 3=210 4=210psi , but i have no blow by so i dont think the rings are shot could it be the valve seals or something....not really concerned bout the engine its gettin swapped just wondering tho..
thanks
Old Sep 1, 2004 | 08:23 PM
bucketheadCRX's Avatar
Default Re: d15b oil eater (301am)
head gasket possibly?? i have a bit of oil in mine too..just changed plugs and..doing a swap soon so..buying plugs and adding oil is cheaper right now ..big props too slapping a band-aid on it and..getting yourself to work and back
Old Sep 3, 2004 | 01:35 AM
CRseXy's Avatar
Default Re: d15b oil eater (buckethead36)
Its possible for the valve Seals. do a leak down test.
ITLNstallion818
Nov 5, 2008 05:32 PM
GripFactoR
May 18, 2003 02:54 PM
B18C1 '96 Coupe
14
Apr 24, 2003 10:38 AM
B18C1 '96 Coupe
Apr 23, 2003 01:50 PM
redteg1
Aug 27, 2002 10:39 AM
