0bd1 in to a 0bd0 need help.....
Old Sep 1, 2004 | 01:05 PM
91siboy's Avatar
Default 0bd1 in to a 0bd0 need help.....
ok we droped a obd1 jdm b16 in t a 91 hatch we get spark but no fuil can some 1 help with this if ne one has a diagram on the way the wires should be for the fuil rail/injegters please help this has been a probem for about a week now can some one help o and do we need obd0 fuil injetors???? pleasehelp thanks
Old Sep 1, 2004 | 07:20 PM
jdmkrazie's Avatar
Default Re: 0bd1 in to a 0bd0 need help..... (91siboy)
hope you have a obd0 dist. already on it. your going to have to use obd0 injectors (b18a1 injectors will work) and keep the resistor box. i can't remember if your stock fuel injector wire plugs will plug up to b series injectors but if they aren't then just get plugs from a b series car and cut and solder them so they fit the injectors. (color should match right up)
also if you don't have an obd0 dist. then either get one from an obd0 b16 or you can use a b18a1 dist. but for the b18a1 to work you'll have to cut the leg towards the front of the car to allow clearance for the VTEC purge assembly. meaning your dist. will only be bolted up with 2 bolts (which is fine)
hope that helped
br8crumb
Jun 1, 2014 10:00 AM
4g4dcruisin
Feb 1, 2010 11:51 AM
BoredRec
Nov 14, 2007 06:36 PM
finallyturboed301
10
Dec 8, 2006 06:35 AM
EK FLY
Jul 25, 2006 09:55 AM
