* How to clean carbon build up in the combustion chambers?? *
Old Sep 1, 2004 | 12:23 PM
itralex's Avatar
Default * How to clean carbon build up in the combustion chambers?? *
how would i go about cleaning the combustion chambers??
i was thinking of using simple green and scotchbrite pads
Old Sep 1, 2004 | 12:46 PM
b_series_boy's Avatar
Default Re: * How to clean carbon build up in the combustion chambers?? * (HypeR1004)
I pulled my head off and used carb cleaner and simple green. I also used the dremel to match the gasket with out taking out the valves. Now that i did all that i wish i would of just got it hot tanked and got it 5 times as clean. To get the carb build up off the top of the pistons i just used a small wire brush tool with the dremel. It works good on the valves to.
Old Sep 1, 2004 | 01:06 PM
dfoxengr's Avatar
first off why do you need them clean?
second. is the head off or on...
if on seafoam...if off, hot tank
2piecescar
Feb 25, 2008 06:12 AM
No-Gi
Feb 8, 2005 05:37 AM
BlueShadow
Mar 29, 2004 04:57 PM
thehondaguru
Mar 14, 2004 07:59 PM
ludesleep
Apr 20, 2003 09:39 AM
