Where's the fuse in Phillips HIDs?
I recently had some front end work done at my local acura dealership. Apparently they did not re-zip tie the wires back, so one of the wires going across the radiator to the driver's side was loose and dragged on the header which burnt right through it. I reconnected the two pieces of wire, but the lights do not come back on. I'm pretty sure there is a fuse in the system and am wondering if maybe it got blown when the wire was burnt through. I just dont know where the fuse is. Can somebody help me please?
Ok, I checked the L and R low-beam fuses under the dash and they are fine. I thought the actual HID system had it's own fuse/fuse box next to the ballasts, No?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">i know my Catz had a fuse next to the ballast, not sure about the phillips</TD></TR></TABLE>
if you mean the small square thing, i dont think that is a fuse...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t »</TD></TR><TR><TD CLASS="quote">
if you mean the small square thing, i dont think that is a fuse...</TD></TR></TABLE>
The small square thing is the ignitor. The larger box is the ballast. I don't think there's a fuse in there. More than likely the fuse under the dash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">
The small square thing is the ignitor. The larger box is the ballast. I don't think there's a fuse in there. More than likely the fuse under the dash.</TD></TR></TABLE>
More than likely it's not a fuse. If the two fuses are fine, it's something else.
Are both lights out or just one?
