so I got in the CRX yesterday, pushed in the clutch and SNAP!
Old Sep 1, 2004 | 07:18 AM
crown14's Avatar
Default so I got in the CRX yesterday, pushed in the clutch and SNAP!
WTF MAN!
So I guess I either snapped the cable completely or most of the strands broke and allowed the remaining ones to stretch horribly.
What do you think? I cant pull the end of it out so I do not think it has completely broken but it definitely is slack as hell now.
This sucks, I was on my way to do important things!
Although the car is 15 years old, so I understand when something breaks here or there...
Old Sep 1, 2004 | 07:25 AM
rioninja's Avatar
Default Re: so I got in the CRX yesterday, pushed in the clutch and SNAP! (crown14)
No big deal. Should only take you 10 minutes tops to replace it
Long as the dealer has them in stock that is
Old Sep 1, 2004 | 07:31 AM
2ride4life's Avatar
how's the clutch pedal? check to make sure that the bracket is ok.
happened to me, but the "snap" was the braket and not the cable.
Old Sep 1, 2004 | 07:34 AM
fourthgenhatchB17's Avatar
Default Re: so I got in the CRX yesterday, pushed in the clutch and SNAP! (2ride4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ride4life &raquo;</TD></TR><TR><TD CLASS="quote">how's the clutch pedal? check to make sure that the bracket is ok.
happened to me, but the "snap" was the braket and not the cable.</TD></TR></TABLE>
when my bracket went out on me, it actually gave out slowly. It juts kept bending and bending and after about 10 minutes, it just broke. I had the new bracket reinforced like a mo fo.
Old Sep 1, 2004 | 08:14 AM
2ride4life's Avatar
Default Re: so I got in the CRX yesterday, pushed in the clutch and SNAP! (fourthgenhatchB17)
yeah, mine was creaking for a bit then "snap". getto-rigged a c-clamp to hold it together ... hehehe didn't feel like dropping the dash at the time.
Old Sep 1, 2004 | 08:40 AM
manson's Avatar
you don't need to drop the dash to swap out the cable.
its really easy... it shouldn't take more than 10 minutes...
Old Sep 1, 2004 | 08:55 AM
2ride4life's Avatar
Default Re: so I got in the CRX yesterday, pushed in the clutch and SNAP! (manson)
sorry for the hijack ... so crown14, was it the cable?
manson ... it was the pedal bracket that snapped for me.
Old Sep 1, 2004 | 08:58 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to drop the dash to swap out the cable.
its really easy... it shouldn't take more than 10 minutes...</TD></TR></TABLE>
Unless you have the Hasport Hydro kit, it's a bitch to replace it then.
Old Sep 1, 2004 | 08:59 AM
EF_LSVtec's Avatar
could be just that plastic thingy that you use to tighten/loosen cable that's attached to the tranny.
Old Sep 1, 2004 | 09:04 AM
4drEF's Avatar
Keyboard Humorist
"so I got in the CRX yesterday, pushed in the clutch and SNAP!"
It must be a yellow CRX.
The curse of the yellow lives on!!!
Old Sep 1, 2004 | 10:31 AM
TwztdSi's Avatar
Default Re: so I got in the CRX yesterday, pushed in the clutch and SNAP! (4drEF)
That happened to me once but it was the throw out bearing spring that broke. Clutch pedal went down and just stayed there.
Old Sep 1, 2004 | 10:37 AM
kurinto's Avatar
Default Re: so I got in the CRX yesterday, pushed in the clutch and SNAP! (TwztdSi)
You don't need to drop teh dash to replace the pedal assembly either, just the steering column. Similar thing happened to me but the arm the cable attaches to on the tranny side seized up and my pedal wouldn't go anywhere.
Old Sep 1, 2004 | 11:09 AM
crown14's Avatar
Nah man this CRX is red! Mostly red at least...
Well I just pulled the cable out and its definitely not broken into two peices, but anyone who knows what this type of cable looks like should remember its made up of many strands- I think there are probably a couple of these still holding together (instead of breaking they actually stretched)... well thats the theory anyhow. I have seen this happen before on many different cars but not on mine!
I can still grab the clutch fork and pull up enough to push the fork/bearing assembly up the input shaft and the pressure plate feels fine... so hopefully its just the cable. Of course Ill take the old one to the store when I buy the new one to compare- a lesson we all should have learned by now.
Old Sep 1, 2004 | 12:10 PM
speed_racer012's Avatar
Default Re: so I got in the CRX yesterday, pushed in the clutch and SNAP! (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">could be just that plastic thingy that you use to tighten/loosen cable that's attached to the tranny.</TD></TR></TABLE>
thats what is was on mine. did it monday on the way to work. got home after work had an extra one in the garage and it only took about 2 mins tops.
teg racer 877
Feb 26, 2010 09:44 AM
Pooby88
Mar 1, 2008 05:55 AM
efyou
10
Mar 11, 2006 08:35 AM
djgruesome
14
Mar 21, 2005 06:10 PM
jondancer
Jun 9, 2003 02:57 AM
