VTEC LIGHT SCHEMATIC
Old Dec 5, 2001 | 04:02 PM
itr0677's Avatar
New User
Default VTEC LIGHT SCHEMATIC
All:
Thought I should post this for those who may be interested...
Email me with questions: heagneyb@earthlink.net
Old Dec 5, 2001 | 04:04 PM
lazyvietboi's Avatar
Default Re: VTEC LIGHT SCHEMATIC (itr0677)
y do u need that resister for??
Old Dec 5, 2001 | 04:08 PM
itr0677's Avatar
New User
Default Re: VTEC LIGHT SCHEMATIC (lazyvietboi)
You need a resistor to convert from 12Volts + to 2Volts = (decrease voltage).
[Modified by itr0677, 3:29 PM 12/6/2001]
Old Dec 5, 2001 | 04:29 PM
ThePunk's Avatar
Who need's a light to tell them their in vtec?
Doesn't the BWAAAHHHHAAHAHAHHHAAAA make it fairly obvious?
Old Dec 5, 2001 | 05:07 PM
JoshRambo's Avatar
Default Re: VTEC LIGHT SCHEMATIC (ThePunk)
my thoughts as well.
Old Dec 5, 2001 | 05:08 PM
Rob :190:'s Avatar
those poor people with quiet intakes and exhausts need a light, hehehe, also doesnt the vtec kick in a few hundred RPMs before the note changes?
Old Dec 5, 2001 | 06:15 PM
SystemGSR's Avatar
Default Re: VTEC LIGHT SCHEMATIC (Rob Maybach)
why not get a 12v LED?
I think it would have been alot easyer to just pickup a 12v LED rahter than doing the math on which resister you need to make 2 volts.
Old Dec 5, 2001 | 06:33 PM
Ibuprofen's Avatar
Default Re: VTEC LIGHT SCHEMATIC (SystemGSR)
nice! exactly what i was looking for.
Old Dec 5, 2001 | 06:40 PM
sackdz's Avatar
Default Re: VTEC LIGHT SCHEMATIC (ITYP3R)
Um, transistors have 3 leads, the"transistor" shown has two. I dunno it's pretty unclear. I don't understand why you need it anyway.......
Old Dec 5, 2001 | 06:41 PM
Big Phat R's Avatar
Good work! Almost looks like Bill Nye Science Guy made the picture.
Old Dec 5, 2001 | 06:49 PM
ThePunk's Avatar
Default Re: VTEC LIGHT SCHEMATIC (sackdz)
I believe that's a Diode.
Why it's there is also a good question.
Old Dec 5, 2001 | 07:00 PM
chad's Avatar
Moderator
very nice senior!!
Old Dec 5, 2001 | 07:06 PM
sackdz's Avatar
An LED IS a diode, you don't need 2..
Nice work though
[Modified by sackdz, 11:09 PM 12/5/2001]
Old Dec 6, 2001 | 04:50 AM
BlackAckeR's Avatar
If I do the math, 12V / 5600 ohms = .0022 amps, or 2.2 ma...
Doesn't seem like a 20-50 ma LED would be too bright with that little current!?!
Old Dec 6, 2001 | 04:54 AM
B18CXr's Avatar
WTF are you calling that diode a transistor????
All you need is the led and resistor. I've made a few of these for the local rice boys.
Old Dec 6, 2001 | 05:14 AM
onyx00's Avatar
Default Re: VTEC LIGHT SCHEMATIC (B18CXr)
Yeah, B18CXr is right, led, resistor, a little solder, some bling bling, and bam.
I'd put one in my car, but I'm always in "VTEK"
Old Dec 6, 2001 | 06:11 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
grr. me bad.
[Modified by Dave-ROR, 10:13 AM 12/6/2001]
Old Dec 6, 2001 | 06:12 AM
itr0677's Avatar
New User
All:
The "DIODE" is a one-way item. I put it in here so that if for some reason voltage tried to go the other way (i.e. bad short) the item would block it and it wouldn't screw up the ECU (the safe way). I know the LED would do this, however, I have seen voltage jump or "arc" LED's before, so this is just a precaution.
Concerning, why not to use a 12V LED or light. You could! I did on my old GSR. However, the mcd's are usually not as bright, nor is there a large selection.
- Brian
[Modified by itr0677, 3:25 PM 12/6/2001]
Old Dec 6, 2001 | 06:21 AM
itr0677's Avatar
New User
My thoughts exactly, 5800RPM on my "R". + It's the "cool" factor for a few bucks and a little time.
- Brian
Old Dec 6, 2001 | 06:23 AM
itr0677's Avatar
New User
Diode YES! BRAIN FART. It was a long day for me. Hey, check the picture out, I updated it. The resistor is approximately 560 Ohm. Anything near it or match the color bands and you should be set. If using a 5 Volt LED, get a 260 Ohm or such. This is what I did with my Blue LED for my VTEC Light in my car (picture shown on clock pod cover).
- Brian
Old Dec 6, 2001 | 09:10 AM
G_S_R's Avatar
itr0677: do you live in the schmidt road/remington blvd area? I think I've seen you driving around before. I work in bolingbrook as well. I drive a white GSR.
Ron
Old Dec 6, 2001 | 09:12 AM
itr0677's Avatar
New User
Default Re: VTEC LIGHT SCHEMATIC (G_S_R)
Yup,
I live around there with my wife and 3 kids.
- Brian
jdmwannabe3
25
Apr 14, 2006 08:57 PM
J's GS-R
Feb 23, 2006 05:45 PM
h22 civic
Jul 28, 2003 05:36 PM
raymondcleung
Sep 5, 2002 05:49 PM
Mr. Softee
Mar 13, 2002 09:24 AM
