CRX HF with Nitrous.... stupid idea yes, but it's the beater
so my beater is getting a swap in spring and i figured it would be fun to spray her until then....
it's an 88 crx hf with 80k miles... runs like a champ, great compression... etc....
so would a dry 35 shot do me in? or could she take a 50 shot for 6 months?
i've got a dry kit.... i'd buy the parts to make it wet if need be.....
-Erik
-Erik
nobody wants to help me blow up my beater....
hummm
surely someone will help give me some advice.
hummm
hahaha, not yet... i will be.... well actually... i don't be until i get off work tonight and head downtown, lol
-Erik <---- will probably spray a 50 and see how it turns out... might as well push the limits of this hf monster
Actually I sprayed my hf motor before I took it out.. I beat the dog **** out of it spraying it from idle and what finally killed the motor was I forgot to fill it up with oil since it burned lots of it..
Try this since you dont care about the motor.. Put a 55 shot(zex is what I used) on it and get it moving in 1st gear with your foot off the clutch and off the gas so your just idleing along.. Then punch the gas.. That little 8 valve hf motor will smoke the front tires..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik_Pb_Foot »</TD></TR><TR><TD CLASS="quote">hahahahahahaha
spraying at idle with a 55 shot... hummmm
you use a wet or dry shot?</TD></TR></TABLE>
Dry.. The motor lasted for like 4 bottles of juice.. When I did pull the motor apart for ***** and giggles I found out that one of the rods was bent a little but no oil ultimitly killed it..
horn12007
17
Jan 13, 2012 07:45 AM
im a monster hehe
25
Aug 9, 2003 07:45 PM
