2.25 mandrel bent or 2.5 custom bent exhaust??
Old Dec 5, 2001 | 03:45 PM
Eggman's Avatar
Default 2.25 mandrel bent or 2.5 custom bent exhaust??
What do you think i should do for exhaust? i found used mandrel bent but its 2.25inch. i was planning to go with 2.5 custom bent piping, but the other is cheaper. when they bend the 2.5 pipe how much does it reduce the diameter too? tia
Old Dec 5, 2001 | 03:57 PM
Cheap Bastard's Avatar
New User
Default Re: 2.25 mandrel bent or 2.5 custom bent exhaust?? (Eggman)
I think they reduce the size about 1/4". I am not sure but it doesn't look too tight. It might also depend on which machine you bend with.
CB
Old Dec 5, 2001 | 04:27 PM
martini's Avatar
Default Re: 2.25 mandrel bent or 2.5 custom bent exhaust?? (Cheap Bastard)
Well, I assume the "custom" bent exhaust is crush bent (or press bent). But the diameter of the pipe around any one bend is going to depend on the angle of the bend, so we wouldn't be able to tell you.
Old Dec 11, 2001 | 10:47 PM
X2BOARD's Avatar
Default Re: 2.25 mandrel bent or 2.5 custom bent exhaust?? (martini)
a 2.5 crush bend, depending on angle can reduce to as small as 1.8-2.0"
(imagine how small the diameter is on a crush/wrinkle bend at 90 degrees)
It depends on your application too.... if you are going the all motor and/or nitrous, you should definitely spend the extra and get the mandrel 2.25 with a hi flo cat and a quality straight thru exhaust, you should be pretty good.
NUISANCE
39
Feb 10, 2011 10:16 AM
A.E Motoring
Mar 8, 2006 05:53 AM
eTec
15
May 21, 2002 02:00 PM
boost killz
Sep 27, 2001 05:26 PM
