Timing belt service
Hey guys i'm gonna be doin my Timeing belt service soon, and wanted to know what else needs to be done besides the Waterpump and drive belts. On my Accord i had that changed plus the seals and balance shaft. Is there anything like that for the Integra?
None of that balance shaft CRAP on Integras, thank goodness.
I am doing the same thing soon, will be doing timing belt water pump, tensioner pulley, all other belts, camshaft seals, and front main oil pump seal. This is the 2nd timing belt change @ 180K miles, for the first one the tensioner pulley is probably fine, might want to do the oil seals, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00siALLmotor »</TD></TR><TR><TD CLASS="quote">I would also recommend a major tune up... Valve adjustment while you're at it... </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foolintherain617 »</TD></TR><TR><TD CLASS="quote">Theres quite a few gaskets that you can take care of too. As long as all the work has been done to take it apart you should do all you can to it.</TD></TR></TABLE>
Will do, thanks!
Will do, thanks!
age_texas
Jun 4, 2012 07:20 AM
The-Kid
Feb 8, 2008 03:47 PM
zracer240
Aug 1, 2005 10:07 AM
