Rust on suspension?
Old Aug 31, 2004 | 06:38 PM
sinister6's Avatar
Default Rust on suspension?
as in the picture. you can see the rust on top of it (under the stiff adjuster)..
does anyone have a problem with it? im thinking of cleaning it with WD40s...any thoughts?
Old Aug 31, 2004 | 06:44 PM
gamby's Avatar
Default Re: Rust on suspension? (sinister6)
Heh, heh--if your location (Taipei) is where you actually are, then you probably don't know what the northeastern United States winters do to a car. It snows, they salt the roads, and eventually most of your car gets covered with rust that is worse than what you have pictured.
Don't worry about a thing. WD-40 and a wire brush should fix that just fine.
Old Aug 31, 2004 | 06:47 PM
sinister6's Avatar
Yeah i have been in Toronto for 2 Xmas. The roads are nasty..
ahh thanks.. will do some brushing and oiling after work.. those rust sorta annoys me..
Old Aug 31, 2004 | 06:48 PM
EKB18BPR3's Avatar
id sand it as best u can and spray it and repeat the process again. if u have ur suspension set indefinitely, id spray some paint on it to prevent reoccurence.
ViperBLUE EJ6
Jan 1, 2010 07:57 PM
ridikk
Suspension & Brakes
Mar 28, 2009 07:21 PM
turbopanda
Nov 17, 2004 09:27 AM
HybridEL
Jul 9, 2003 08:05 PM
