Rust on suspension?
Rust on suspension?
as in the picture. you can see the rust on top of it (under the stiff adjuster)..
does anyone have a problem with it? im thinking of cleaning it with WD40s...any thoughts?
Re: Rust on suspension? (sinister6)
Heh, heh--if your location (Taipei) is where you actually are, then you probably don't know what the northeastern United States winters do to a car. It snows, they salt the roads, and eventually most of your car gets covered with rust that is worse than what you have pictured.
Don't worry about a thing. WD-40 and a wire brush should fix that just fine.
Yeah i have been in Toronto for 2 Xmas. The roads are nasty..
ahh thanks.. will do some brushing and oiling after work.. those rust sorta annoys me..
id sand it as best u can and spray it and repeat the process again. if u have ur suspension set indefinitely, id spray some paint on it to prevent reoccurence.
turbopanda
11-17-2004 09:27 AM
